applying felt
Forum topic by jeffswildwood posted 03-28-2013 08:37 PM 1312 views 1 time favorited 12 replies Add to Favorites Watch
View jeffswildwood's profile
jeffswildwood
3188 posts in 1975 days
03-28-2013 08:37 PM
Topic tags/keywords: question
Hi all, I just finished another box and the future owner wanted space for 10 watches and a space for rings in the lift out tray. I accomplished this task OK but then came the felting. Normally i cut to fit then use elmers glue (white) to hold it in place. Had a time of this for some reason this time. What method do you use. I seen a video that said to apply felt to heavy paper, trim then glue down. Like to hear other methods!
-- We all make mistakes, the trick is to fix it in a way that says "I meant to do that".
12 replies so far
View Nicky's profile
Nicky
695 posts in 4089 days
#1 posted 03-28-2013 08:44 PM
I use a flocking kit. Check out http://www.youtube.com/watch?v=PJFjorzlI3k
This is much less frustrating then cutting/gluing pieces of felt.
-- Nicky
jeffswildwood
#2 posted 03-28-2013 09:46 PM
Nicky, thanks for the tip. I always wondered how others seem to get that velvet look while mine still looked like felt. Now on to amazon to check on this.
View Jim Finn's profile
Jim Finn
2656 posts in 2919 days
#3 posted 03-28-2013 10:10 PM
I use flocking also. The “glue” they sell in the kits is just a slow drying paint so I now just buy that part locally at lower cost.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
jeffswildwood
#4 posted 03-28-2013 11:44 PM
I checked amazon and DonJer website. It is quite pricy but I would say a pound would go a long way. Jim, how do you match the color. I still love the look and it does look a lot easier then the cut and glue method using felt.
View DaleM's profile
DaleM
958 posts in 3381 days
#5 posted 03-28-2013 11:54 PM
I have used the self-stick felt sheets in a couple of gun cabinets and I think it worked well. It sticks well to a lacquered surface.
-- Dale Manning, Carthage, NY
View Richard Miller's profile
Richard Miller
139 posts in 1968 days
#6 posted 03-29-2013 12:32 PM
I took tightbond glue thinned it down a bit so it is easy to brush and it worked great.
-- Dick F,Burg Iowa
View lj61673's profile
lj61673
261 posts in 2397 days
#7 posted 03-29-2013 10:34 PM
Here is how I do it…I buy 20” x30” x 1/4” rigid foam boards from a local art store (michaels). Cut the board to match the inside box size. Using self adhesive velvet from Rocklers, I wrap the cut boards with the velvet. (cut it slightly larger and fold it over). The felt/velvet will make the wraped board slightly larger which will make it a snug friction fit. Pressing it into place compresses the foam board slightly, hiding any imperfections in the cut board. Makes a perfect fit every time.
Much more professional than using cardboard.
View LookingGlass's profile
LookingGlass
77 posts in 2106 days
#8 posted 03-29-2013 11:05 PM
Here is how I do it…I buy 20” x 30” x 1/4” rigid foam boards from a local art store (michaels). Cut the board to match the inside….....
I use a similar technique. Except I use 1/4 inch fiber board and hot-glue the velvet. Comes out nice and I am pleased with the results….been using this technique for many years.
Hope this helps.
-- Take care.....Ed
jeffswildwood
#9 posted 03-30-2013 12:56 PM
Thanks all for all the tips! Gave me a lot of ideas. The foam would make a softer base that I really could have used for the tray, (hold ten watches). Looks like I now have several options I didn’t know about before. When you spend all that time on a project, you really want the finishing touches to look good. Thanks for the input!
lj61673
#10 posted 03-30-2013 05:56 PM
Jeff, the foam board is rigid and has a paper backing on both sides. Very firm, not an issue at all. Also the velvet or felt has a self adhesive backing. Messy glue is a no go.
View HorizontalMike's profile
HorizontalMike
7757 posts in 2912 days
#11 posted 03-30-2013 06:12 PM
I have flocked the inside tubes of two of my telescopes with the self-stick felt and things are holding 24/7/365 in the heat and cold of Texas weather without fail over the past 5yr or so.
http://www.horizontalheavens.com/Flocking%20LX200.htm
View ChuckC's profile
ChuckC
828 posts in 2933 days
#12 posted 03-30-2013 11:05 PM
For something flat like a bottom I’ve used sticky back felt. For irregular shapes you can’t beat flocking. A little flocking material goes a long way and it’s really easy to do.
