depth of tenon for cabinet doors
Forum topic by Pabs posted 03-28-2013 02:50 PM 2798 views 0 times favorited 11 replies Add to Favorites Watch
View Pabs's profile
Pabs
259 posts in 3688 days
03-28-2013 02:50 PM
Hi all
I was just on the wood magazine web site and they had this article on making frame and panel doors (see here)
they make tenons only 3/8” in depth to basically match the depth of the groove. you can see it in the following
pdf
is 3/8 tenons enough to get a good solid joint? or should they be deeper
-- Pabs
11 replies so far
View Lee Barker's profile
Lee Barker
2170 posts in 3085 days
#1 posted 03-28-2013 03:20 PM
That’s how we’ve been doing it since Mr. Shaper invented Stile and Rail Set #1, Pabs. Careful gluing and it’s a door that will still be intact when your piece appears on Antiques Roadshow in 2070.
Kindly,
View Pabs's profile
Pabs
#2 posted 03-28-2013 06:18 PM
failed to mention this would be in kitchen cabinets..lots and lots of abuse on those
I’ve never done them with tenons that small.. I typically go in at least 1 inch.. but mind you i’m no pro.
just feels like there would not be enough to get a solid joint…would certainly speed up the building process by doing them this way
-- Pabs
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 2307 days
#3 posted 03-28-2013 06:26 PM
Lee Barker,”That’s how we’ve been doing it since Mr. Shaper invented Stile and Rail Set #1, Pabs. Careful gluing and it’s a door that will still be intact when your piece appears on Antiques Roadshow in 2070.”
I could say something to back Lee’s position, but I couldn’t say it better myself.
-- Who is John Galt?
View Charlie's profile
Charlie
1100 posts in 2520 days
#4 posted 03-28-2013 06:29 PM
I built all mine with 3/8 tenons. Mine are very simple shaker style (mission style?) with a plain panel. I used 1/2 inch ply for the panels, rabetted the back of the panel and glued and clamped the rails and stiles together. I can tell you they are EXTREMELY strong. Very simple on the table saw with a dado setup too.
View Nicky's profile
Nicky
695 posts in 4326 days
#5 posted 03-28-2013 06:31 PM
A tenon that fits snug will will give the joint the mechanical strength it needs for a kitchen application. The glue will hold it together. The rail/stile method that Lee mentions is the most common in production doors.
Just to convince yourself, make a door with this method, let the glue cure (depending on the type you are using) and try an break it apart. I’ll bet you can break everything except the actual joint.
I’m always inclined to over build (an over think) my projects. I’ve learned to get comfortable with this method of making doors because it’s quick and easy to make with a router and stands up to the test of time.
-- Nicky
joeyinsouthaustin
#6 posted 03-28-2013 06:34 PM
+1 nicky. Also a very good way to put it… and the best way to test it… kinda fun too. :)
View Pabs's profile
Pabs
#7 posted 03-28-2013 06:35 PM
thanks for all the replies guys… I’ll follow wisdom and go down this path!
on the subject of glue…what would be the best glue for this type of application ? the stiles and rails will be made of oak
-- Pabs
Craftsman on the lake
2842 posts in 3672 days
#8 posted 03-28-2013 06:45 PM
When you make raised panel cabinet doors with the appropriate router bits the rails and stiles fit together with about 3/8” of wood. All my doors stay together that way. I recently did a bench/chest that way too. Seems to work okay.
View Woodmaster1's profile
Woodmaster1
1089 posts in 2821 days
#9 posted 03-28-2013 06:57 PM
I only had two doors that came apart due to abuse in 22 yrs. The glue held the wood split. This is after 7 kids and their friends.
View pintodeluxe's profile
pintodeluxe
5815 posts in 3048 days
#10 posted 03-28-2013 07:03 PM
I like 1/2” better. Mostly because I can give a solid wood panel room to move, but never fear that the panel will shrink too much. I make my grooves 1/2” deep, and my tenons 1/2” long.
If the panel is plywood, it is not as critical because the panel can be glued in place.
joeyinsouthaustin
#11 posted 03-28-2013 08:07 PM
Pabs…. any good pva glue, like tightbond two or three. Stainable pva glues on the market react with oak, so I like the color match of TB III to oak for stain grade.
