Cleaning tools
« back to Hand Tools forum
Forum topic by 12strings posted 03-27-2013 10:43 PM 1074 views 0 times favorited 7 replies Add to Favorites Watch
View 12strings's profile
12strings
434 posts in 2471 days
03-27-2013 10:43 PM
Could you describe your routine, if any, for wiping, cleaning tools after use? Specifically
1. What do you do most regularly to things like saws and planes that cut wood?
2. How often do you do any sort of cleaning?
3. Is there anything special you would do after using your tools on wet, pressure-treated lumber?
Thanks!
-- I'm strictly hand-tool only...unless the power tool is faster and easier!
7 replies so far
View Brandon's profile
Brandon
4152 posts in 3038 days
#1 posted 03-27-2013 11:12 PM
A lot of people recommend putting camellia oil on their tools:
http://www.highlandwoodworking.com/camelliaoilspray240ml.aspx
I haven’t used it yet myself, but I plan on picking up a bottle during my next visit to Highland.
-- "hold fast to that which is good"
View paratrooper34's profile
paratrooper34
915 posts in 3038 days
#2 posted 03-27-2013 11:33 PM
A couple of times a year, before summer and mid-winter, I clean them up by wiping them down and applying some paste wax. That’s it. My shop is in the basement and I have dehumidifiers working full time in the summer so no worries.
I have not and will not touch pressure treated wood with my hand tools. I would use my skill saw only (with appropriate dust protection).
-- Mike
View BigRedKnothead's profile
BigRedKnothead
8528 posts in 2069 days
#3 posted 03-27-2013 11:35 PM
I’m a wd40 guy. I buy it by the gallon and spray down stuff routinely. Never had it affect a finish. I think only stuff with silicone will.
-- "At the end of the day, try and make it beautiful....because the world is full of ugly." Konrad Sauer
View Kreegan's profile
Kreegan
1452 posts in 2233 days
#4 posted 03-28-2013 12:54 AM
I use camellia oil on my planes whenever I use them. I have a microfiber towel that’s pretty well soaked in camellia oil at this point. I rub them with it before putting them back on the shelf. For saws I periodically rub some paraffin wax on the saw plate, usually when I notice them starting to bind a bit. Chisels and gouges I don’t really do much to.
View mbs's profile
mbs
1657 posts in 3027 days
#5 posted 03-28-2013 02:22 AM
I use lacquer thinner and green scotch bright to take the surface spots off then use johnsons paste wax. I do it when the surface gets tacky or I see some surface rust appearing.
I use light oil like 3-1 oil on the threads of the planes.
-- Sorry the reply is so long. I didn't have time to write a short reply.
View jamesicus's profile
jamesicus
132 posts in 2778 days
#6 posted 03-28-2013 08:37 PM
It is so very dry here in the desert that protection against corrosion is normally not necessary. During the summer rainy season I just wipe down my tools after use with a lightly oiled (gun oil) rag.
James
View sikrap's profile
sikrap
1121 posts in 3445 days
#7 posted 03-29-2013 01:26 PM
I also use a rag with Camelia oil. I wipe down my planes and chisels after use. I also take out the iron and CB when I’m done with a project and clean out any remaining shavings/sawdust. If you decide to use Camelia oil, I suggest buying it at your local Asian market rather than Rockler/Highlend etc. Its much less expensive.
-- Dave, Colonie, NY
