Strange wear patterns
« back to Hand Tools forum
Forum topic by bandit571 posted 03-27-2013 06:35 PM 960 views 0 times favorited 6 replies Add to Favorites Watch
View bandit571's profile
bandit571
20000 posts in 2682 days
03-27-2013 06:35 PM
Topic tags/keywords: question plane sharpening
The last few plane irons I have restored, have the center of the edge worn away. Instead of a cambered effect, these were the opposite. The outside corners were sticking out more than the middle areas.
First few trips down the sandpaper, the corners are sharp. The middle of the edge? Not even touched. Back to the grinder and grind a new edge. Now the bevel is consistent acroos the edge.
Question is: Why all the wear in the center of the edge? It takes a lot of work to bring these type of irons back to make a shaving like this
Just not sure what the previuos owners were doing, to wear away the center of the edges.
View Kreegan's profile
Kreegan
1452 posts in 2145 days
#1 posted 03-27-2013 06:51 PM
Edge jointing, roundovers or planing round stock most likely. The part of the iron that gets used most wears the most.
View Dan's profile
Dan
3630 posts in 2879 days
#2 posted 03-27-2013 06:54 PM
^ Agree… I have run into a number of old irons where the center of the iron is dipped lower then the sides. Most likely the plane was previously used for edge work or narrow stock where the full iron was not used.
-- Dan - "Collector of Hand Planes"
View Dan's profile
Dan
#3 posted 03-27-2013 06:57 PM
I also want to add that sometimes you will run into an old plane where the middle area of the sole is dipped lower then the sides along the length of the plane. This is also due to the plane previously being used primarily for narrow edge work.
View Johnnyblot's profile
Johnnyblot
319 posts in 2275 days
#4 posted 03-27-2013 07:06 PM
Using stones that are convex will produce the same thing.
Beware Of Hollow Stones” is the first line of my notes taken when being taught by David Charlesworth on Grinding and Honing. Simple but True.
Cheers
John
-- Gossamer shavings just floating around the back yard….-Bandit
bandit571
#5 posted 03-27-2013 07:14 PM
Lets see, i got the sole of the latest plane looking good
Then turned to work on the iron.
By using the side of the grinder’s wheel, I got the back flat. As for the “business side”
This is after it was worked over on the grinder. With a water quench as needed. I had it set up for a run on the beltsander, and then on to the stones. Followed that up with some 2k paper, and away it went. Spent more time on the iron, than the rest of the plane.
bandit571
#6 posted 03-28-2013 12:51 AM
I will be getting a Dunlap Block plane tomorrow in the mail. Will be checking the iron on that one, as well. Although, I did have one block plane show up with a cambered iron….
View Don W's profile
Don W
18715 posts in 2566 days
#7 posted 03-28-2013 04:37 PM
I’ll agree with John, out of wack water stone.
Don W
#8 posted 03-28-2013 04:37 PM
dup deleted
