Creating microbevel on new hand plane blade
« back to Hand Tools forum
Forum topic by GusG posted 03-27-2013 07:58 AM 789 views 0 times favorited 6 replies Add to Favorites Watch
View GusG's profile
15 posts in 1827 days
03-27-2013 07:58 AM
I have two new LV bevel-up blades. One at 50 deg and the other at 38 deg. I want to off course add a microbevel to these blades. Can I go straight to a 4000x water stone or do I initially have to use a 1000x or 1200x waterstone to create the microbevel?
View popmandude's profile
109 posts in 2952 days
#1 posted 03-27-2013 11:38 AM
If the blades came sharp the way LV blades are known to do 4000 would be a good place to start for that micro-bevel. I would however drop down to 1000 if I done any work flattening the back at all. On a new blade I always start on the back no matter where the blade came from.
Good luck
View GusG's profile
#2 posted 03-27-2013 12:08 PM
I started off by sharpening at 4000x for the microbevel. Did not get any good results. I resharpened at 1000x and then of course progressed to the finer grits. Both blades are performing great now. I did not lap the back. In the carton, LV provides a small leaflet stating the back of the blade has been lapped flat (forget the tolerance), so I did not need to do that step. I have two of their other blades and I did not have to lap the back of the blades either.
View jap's profile
1251 posts in 1986 days
#3 posted 03-27-2013 12:15 PM
GusG, I would still lap the back of the blades to a higher polish, LV blades are flat but has a courser grind than what your fine stone would leave. you’ll get a finer edge
-- Joel
View GusG's profile
#4 posted 03-27-2013 12:23 PM
Ok, understood. I will lap the back of the blade. Do I need to resharpen over again? I did polish the edge of the blade to remove the wire edge created during sharpening the microbevel.
View sikrap's profile
1121 posts in 3291 days
#5 posted 03-27-2013 12:30 PM
You might have to touch up the secondary/micro bevel, but that would be it.
-- Dave, Colonie, NY
View GusG's profile
#6 posted 03-27-2013 12:31 PM
Ok, thanks guys.
