Freud router bits opinions
Forum topic by TopamaxSurvivor posted 03-26-2013 04:12 PM 1778 views 0 times favorited 32 replies Add to Favorites Watch
TopamaxSurvivor
18265 posts in 3669 days
03-26-2013 04:12 PM
Topic tags/keywords: router bits freund
Anyone have a review of Freund router bits. The only one that popped up on a search was for insert bits.
32 replies so far
View jaydubya's profile
jaydubya
183 posts in 2805 days
#1 posted 03-26-2013 04:19 PM
Are you talking about Freud bits? possibly the spelling error isnt allowing results to come up for you
View pintodeluxe's profile
pintodeluxe
5652 posts in 2806 days
#2 posted 03-26-2013 04:32 PM
I like Freud, Rockler, and Whiteside carbide tipped router bits. They all seem to perform well for a long time.
Come to think of it Amana is good too.
Keep them sharp with a little diamond file set, and you will be in business for a long time.
View Marcus's profile
Marcus
1163 posts in 2012 days
#3 posted 03-26-2013 04:36 PM
If you are talking about Freud, I’ve had very good luck w/ their bits.
View helluvawreck's profile
helluvawreck
31017 posts in 2859 days
#4 posted 03-26-2013 04:40 PM
I like Freud but Whiteside is my favorite.
helluvawreck aka Charles
TopamaxSurvivor
#5 posted 03-26-2013 04:56 PM
Thanks, looks like I misspelled them, I’ll edit that. Any advantage to bigger diameter bits over a 1/4” fro flush cutting and trimming?
4980 posts in 2486 days
#6 posted 03-26-2013 05:04 PM
The larger diameter buts will cut more smoothly….you can get chatter with the 1/4” bits. That said, I’ve never used a flush bit of any kind that’s less than 1/2” shank, my only experience with the smaller ones is with spiral and fluted bits that have no bearings.
View stefang's profile
stefang
15881 posts in 3327 days
#7 posted 03-26-2013 06:11 PM
They are not the very best, but they will certainly do acceptable work.
View NiteWalker's profile
NiteWalker
2737 posts in 2570 days
#8 posted 03-26-2013 06:23 PM
Freud, Whiteside and CMT are all great bits.
You want 1/2” shank as much as possible. Less vibration when cutting makes for a cleaner cut. You can alleviate this when using 1/4” shank flush trim bits by trimming as much waste away as possible (aim for leaving no more than 1/16” of waste).
View Bobsboxes's profile
Bobsboxes
1367 posts in 2657 days
#9 posted 03-26-2013 06:55 PM
I have a bevel set of Freud that have built several sets of cupboards, some hickory. Not a problem, I also use Rockler, Whiteside, amana, and lots of cheap Grizzly. Keep them clean, dress them with a diamond file and oil the bearings. I like my big dia. ( 1” ) Rockler and Grizzly bearing bits for pattern routing.
-- Bob in Montana. Kindness is the Language the blind can see and deaf can hear. - Mark Twain
View devann's profile
devann
2246 posts in 2685 days
#10 posted 03-26-2013 07:13 PM
I’ve used Bosch and Amana router bits with good & affordable results. I even was going to write a positive review for the 1 1/8” template bit I use for routing treads in stair stringers. Just haven’t gotten to it.
View Manitario's profile
Manitario
2630 posts in 2876 days
#11 posted 03-26-2013 07:22 PM
Most of my bits are Freud; they cut smoothly and stay sharp.
View Dan'um Style's profile
Dan'um Style
14172 posts in 3976 days
#12 posted 03-26-2013 09:35 PM
Never had any problems with my Freud bits. Always cut fine. Have only used the 1/2” shank configuration.
HillbillyShooter
5811 posts in 2285 days
#13 posted 03-26-2013 09:44 PM
Freud bits are very good, as are CMT and Amana, but my favorites are all bits by Whiteside. Also, the larger the shank diameter the more stable the cutting. If possible use 1/2” shank for the best cut.
View woodbutcherbynight's profile (online now)
woodbutcherbynight
4497 posts in 2402 days
#14 posted 03-26-2013 11:17 PM
1/2” shank like many suggested is spot on. Save the old ones for odd work and such but def go with 1/2”shanks.
View Roger's profile
Roger
20928 posts in 2797 days
#15 posted 03-26-2013 11:40 PM
I like pretty much any Freud products. Seem to be high quality, IMO
showing 1 through 15 of 32 replies
