Expanded html guide
« back to LumberJocks.com Site Feedback forum
Forum topic by Smitty_Cabinetshop posted 03-26-2013 03:12 PM 1286 views 1 time favorited 39 replies Add to Favorites Watch
Smitty_Cabinetshop
15831 posts in 2860 days
03-26-2013 03:12 PM
I’d like the ability to wrap text around an inserted image, for example. Can the html guide be expanded to include a few more ‘how to’ sections on formatting within a post?
  • wrap text
  • tables
  • lines between sections of text
I’m not a coder, but would like to have a couple more options when tocomes to composing longer entries in a visually interesting way.
39 replies so far
View Mosquito's profile
Mosquito
9574 posts in 2534 days
#1 posted 03-26-2013 03:28 PM
It would be nice, but they’d have to make things a little more robust before some of that should happen (I think you know what I’m talking about…)
Wrapping text around an image would be kind of nice. The tables that they allow are relatively limited, in that they will always be styled a certain way (as best I could manage). Would be nice to be able to have horizontal dividers that weren’t made up of a bunch of dashes…
-- Mos - Twin Cities, MN - http://www.youtube.com/MosquitoMods - http://www.TheModsquito.com
View Don W's profile
Don W
19055 posts in 2809 days
#2 posted 03-26-2013 04:10 PM
it would be nice if the emails came in html format as well.
View Dave's profile
Dave
11429 posts in 3082 days
#3 posted 03-26-2013 04:34 PM
We are trapped to what they have turned on or off in the forum.
Do something in a html editor and past it here and see what happens.
ɟɟnʇs ǝɯos op uɐɔ noʎ
Smitty_Cabinetshop
#4 posted 03-26-2013 05:01 PM
Here goes.
Here the hspace is 10 and the vspace is set to 5, giving the image a much more professional look. Taking into account the small space that already exists below the baseline, the values of vspace was reduced by a small amount. The overall effect is very subtle, but noticable upon close study. The visual gap along the top, bottom, and right size, all appear to be even, though different values were used for hspace and vspace (hspace=”10”, vspace=”5”).
Smitty_Cabinetshop
#5 posted 03-26-2013 05:02 PM
Hmmmm…. won’t align left.
Smitty_Cabinetshop
#6 posted 03-26-2013 05:03 PM
And taking out the ‘left’instruction has no impact. Image isn’t really wrapped by text, either. Sigh.
Smitty_Cabinetshop
#7 posted 03-26-2013 05:10 PM
little work on the fine DMT showed it wasn’t flat on the outer surface of either of the two nickers. I don’t want to remove a ton of material here; the outer surface of each spur needs to be coplanar with the side(s) of the main bod of the tool. That said, I want them flat to fully register to the sidewalls of each cu
Returning to normal LJ text entry. Now a table without border, maybe??
Smitty_Cabinetshop
#8 posted 03-26-2013 05:12 PM
^ Progress!
Smitty_Cabinetshop
#9 posted 03-26-2013 05:18 PM
Defining a table gives auto border. Image can be sized. Interesting.
Smitty_Cabinetshop
#10 posted 03-26-2013 05:31 PM
Here’s an example of a story being ‘interrupted’ with an image and sidebar, where the text is above the pic as well as
SIDEBAR: DMT Work
Work on the fine DMT showed it wasn’t flat on the outer surface of either of the two nickers. I don’t want to remove a ton of material here; the outer surface of each spur needs to be coplanar with the side(s) of the main bod of the tool. That said, I want them flat to fully register to the sidewalls of each cu
below the pic. Wonder if it’s too confusing?
View Tugboater78's profile
Tugboater78
2764 posts in 2433 days
#11 posted 03-26-2013 05:36 PM
-- "....put that handsaw to work and make it earn its keep. - summerfi" <==< JuStiN >==>=->
Smitty_Cabinetshop
#12 posted 03-26-2013 05:46 PM
An example of a table in a post. No idea why so much space.
Waco Dallas Fort Worth
El Paso Corpus Christi Houston
Austin San Antonio Arlington
Mosquito
#13 posted 03-26-2013 05:59 PM
for why there’s so much space, it’s because it’s taking all the carriage returns within the table (code), and putting them before it. This was something I found a while ago too. You have to do the table as a single line (which is ugly, and annoying to edit, but will remove that white space).
the above example would need to be:
<table><tr><td>Waco</td><td>Dallas</td><td>Fort Worth</td></tr><tr><td>El Paso</td><td>Corpus Christi</td><td>Houston</td></tr><tr><td>Austin</td><td>San Antonio</td><td>Arlington</td></tr></table>
you can also use <th> tags instead of <td> to get a cell with a background and different colored text (table header)
headernot-header
Smitty_Cabinetshop
#14 posted 03-26-2013 06:03 PM
Here’s the site I’m using for donor material, FWIW.
http://howdyyall.com/webresources/CodeEditor/index.cfm
Smitty_Cabinetshop
#15 posted 03-26-2013 06:14 PM
I remember you saying that before, now that I see it again. :-)
Any idea how to wrap text without defining a table? The example above limits it to use as a sidebar with pic, I think…
showing 1 through 15 of 39 replies
