Gloss problem
Forum topic by John in SD posted 63 days ago 186 views 0 times favorited 4 replies Add to Favorites
View John in SD's profile
John in SD
34 posts in 349 days
63 days ago
Topic tags/keywords: problem gloss cabinets spray painting latex lacquer question
I have spray painted our kitchen cabinet doors a high gloss latex….they look great but not as glossy as moma wants….wondering if I can over coat it with water based gloss lacquer.
Has any of you done this? Or is there something else you would suggest
-- I'm not slowing down,everythings just going by faster!
View SteveB's profile
SteveB
23 posts in 594 days
63 days ago
Let the paint dry a few days, then wet-sand it with fine sandpaper. 1000 grit ought to do it. After that, spray again, but add some Floetrol to the paint.
You can finish it off with lacquer or shellac if you want. Experiment with some scrap to see how different things turn out.
Next time, use an oil-based paint. There are some nice latex paints out there, but I’ve yet to find one that gives as nice a finish as oil. (You can add Penetrol to oil paint to make it finish better.)
-- Steve B - New Life Home Improvement
View BeechPilotBarry's profile
BeechPilotBarry
410 posts in 239 days
63 days ago
I have mixed Pratt & Lambert latex paint into ML Campbell Ultrastar waterborune lacquer with excellent success.
I keep the paint to less than 20-30%.
-- - Real men read directions
View CharlesNeil's profile
CharlesNeil
88 posts in 407 days
63 days ago
yes you can topcoat with any good waterbased gloss top coat..and if ya let it dry several days you can topcoat with a solvent based
John in SD
62 days ago
Thank ya’ll for the help…..I knew I could count on ya
Bookmark And Share This Page
