LPS 1 - Will it work in a wood shop ?
Forum topic by 1yeldud1 posted 03-26-2013 01:44 AM 984 views 0 times favorited 5 replies Add to Favorites Watch
View 1yeldud1's profile
1yeldud1
301 posts in 3162 days
03-26-2013 01:44 AM
The factory I work at uses “LPS1” spray lube and I have an opportunity to purchase at cost. I did a search on the internet and the manufacturer says it does not contain silicone. I am needing something to put on my precision hand tools to keep the rust at bay. Has anyone used this spray in there wood shop with good results ? is ther any other spray that I can use on these steel surfaces – tried paste wax and I dont like the results on my precision tools – Thanks for the replys.
5 replies so far
View PASs's profile
PASs
595 posts in 3218 days
#1 posted 03-26-2013 01:48 AM
I use LPS2 and LPS3 everywhere.
But haven’t used LPS1 yet…just WD-40…and I use it on a lot of my tools.
I just make sure any tools that come in contact with wood are wiped clean before use.
-- Pete, "It isn't broken, you just aren't using it right."
View Fuzzy's profile
Fuzzy
298 posts in 4108 days
#2 posted 03-27-2013 02:54 AM
I LOVE the stuff … spray it on all of my tool surfaces … wipe it on hand tools … use it in an ultrasonic tank to clean small parts … GREAT STUFF. I usually buy a 5 gal. pail of it and split it with a friend. I put it in a sprayer that you can charge with compressed air after adding the liquid … MUCH more economical.
-- - dabbling in sarcasm is foolish … if you’re not proficient at it, you end up looking stupid … ... ...
1yeldud1
#3 posted 03-27-2013 09:21 AM
In a wood shop no problems with “spoiled” finishes ?
View RonInOhio's profile
RonInOhio
721 posts in 2984 days
#4 posted 03-27-2013 09:31 AM
Some woodworking magazine did a comparison of around 7 rust inhibitor products and I’m pretty sure LPS came out near the top if not at the top in their testing. Need verification but I know it did well in their tests.
View PASs's profile
PASs
#5 posted 03-27-2013 12:47 PM
1yeldud1, can certainly be a problem.
As a hobbyist who does his own auto work, mr fixit work, and woodwork, all in a two-car garage, cross-contamination is always a concern, and requires extra precautions when switching genre’s.
I’ve yet to ruin a finish with oil….but I do have a lot of automotive stuff (and everything else) covered in sawdust.
BTW every once in a while I hook an electric leaf blower up and blow out the shop (full respirator of course).
Amazing what blows out from behind nooks and crannies.
