Question for turners
« back to Woodturning forum
Forum topic by RussellAP posted 03-25-2013 07:40 PM 1120 views 0 times favorited 15 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
3103 posts in 2256 days
03-25-2013 07:40 PM
I’d like to make some very delicate finials for my bowls but mounting a piece on the lathe is my greatest challenge. I dont want poke marks so I’ve been gluing an old tenon on to the drive end and just using another tenon on the tail end, but nothing seems to hold through the entire turning process.
I am ordering a hot glue gun now and I’d lilke to know if there are any special glue sticks I should order to go along with it for this purpose.
I’ve tried Titebond, and CA and nothing seems to hold.
15 replies so far
View Kreegan's profile
Kreegan
1452 posts in 2116 days
#1 posted 03-25-2013 08:14 PM
Do you have a collet chuck? That seems to be the most common way to hold finials that I’ve seen. PSI sells a nice one for around 80.
RussellAP
#2 posted 03-25-2013 08:25 PM
Rich, one of the things I want to avoid is not being able to use the entire blank. Most pen blanks are only about 4” long so by the time you chuck it, you’ve lost an inch. Ideally I want to extend the blank on both ends and that way I can turn the entire thing.
View Mip's profile
Mip
453 posts in 2048 days
#3 posted 03-25-2013 08:34 PM
You can always make your own collet chuck. Take your smallest face plate, mount a 3×3” block about 3 or 4 inches long to it, turn the block round, drill a hole in the end opposite the faceplate, take this assembly to the bandsaw and saw some kerfs through the hole and put on a small hose clamp on that end. Now when you turn the rough lumber for the spires, turn one end into a tenon the same size as the hole in your chuck, mount it in the chuck and tighten down the hose clamp to hold the wood. Now you can turn the spires whatever design you want.
View Wildwood's profile
Wildwood
2300 posts in 2104 days
#4 posted 03-25-2013 09:10 PM
RussellAP
#5 posted 03-25-2013 09:21 PM
Bill, yes, finials. The word escapes me.
View TheDane's profile
TheDane
5405 posts in 3633 days
#6 posted 03-25-2013 11:37 PM
Russell … I have had good luck gluing small finial blanks to a waste block using Weldbond … http://www.weldbond.com .
I use waste blocks screwed to face plates, but it is just as easy to cut a tenon and use them in a chuck.
I support the other end with the tailstock until I need to turn the tip. Note that Weldbond is not a fast-drying glue
View REO's profile
REO
928 posts in 2044 days
#7 posted 03-25-2013 11:50 PM
the end grain will always make a weak glue joint. back drill the stock for a dowel and glue the dowel in place. chuck up the dowel portion and do your turning. part off the dowel and if you want to back drill again, using the shavings as a filler to fill the hole and hide the dowell. very delicate finials are usualy progressively turned from the tailstock end and never use the tailstock for support except for initial rounding of the blank.
Wildwood
#8 posted 03-26-2013 11:53 AM
Learning to turn finals lot easier practicing on scrap wood turning between centers whether want short or long finials. You can get basic shape including tenon with tailstock support. Mark off waste allowance with pencil lines on left and right of finial. Turn your finial leaving enough wood to support as you go. I work from tip back to bead or onion, tenon, then sand. Will take a parting tool and part half way on tenon end so can saw off later. Then take a skew and finish tip. Apply finish off lathe.
Do about the same when blank mounted in my chuck. Only difference except once get basic shape remove tailstock support and continue turning, sanding, finishing.
Use thin parting, Bedan, ½ “ skew, and 3/8 “ spindle gouge to turn finials. One old spindle gouge been modified into detail gouge.
Wish had a ¼” round skew. Thought about getting a step center but my 2 prong drive center works so will save my money. Besides chuck with right jaws makes live easier.
http://www.packardwoodworks.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=packard&Product_Code=110601&Category_Code=lathes-acc-cent-steb
-- Bill
View bondogaposis's profile
bondogaposis
4690 posts in 2321 days
#9 posted 03-26-2013 01:47 PM
A collet chuck is the way to go. Watch this video, very little waste.
-- Bondo Gaposis
Kreegan
#10 posted 03-26-2013 02:09 PM
Jinx, Bondo! I was just about to post a link to that. :-D
RussellAP
#11 posted 03-26-2013 02:13 PM
@Bondo, I’m going to work on this today, I think my drill collet might work in the drive side. So all I need is to make a tenon that will fit it.
I need a poster of Capt Eddie in my shop.
TheDane
#12 posted 03-26-2013 02:22 PM
Russell—Capt Eddie will probably have the posters available in the Fall Catalog. :>}
Seriously … if you have a Jacobs chuck, you can make that work, too. But the colletts available from http://www.littlemachineshop.com too.
RussellAP
#13 posted 03-26-2013 04:06 PM
Gerry, I just turned my first finial. Forget the type of wood, but it was pretty soft.
I used my regular chuck, but held the 3/4×3/4 piece inside where the jaws have about 4mm grab. It’s just enough with the tail stock to get a tenon out of before it goes flying, and fly it does.
After the tenon I chuck in my drill chuck on the drive side and using the tail stock I can turn it out.
I finished up on the grind wheel that I use to sharpen tools. I think it came out pretty well. I’ll post it in forums.
View jtriggs's profile
jtriggs
177 posts in 3787 days
#14 posted 03-28-2013 02:53 PM
Loved that video from Capt. Eddie. Went right to the littlemachineshop.com website and ordered 3 #2 MT collets. Only $33. Got a 1/4”, 3/8” and 1/2”. That should cover anything I want to make.
Now I just need the skill to turn those fine, delicate parts. I’m more of a table-leg-turning guy.
Glad to see this woodturning forum on LJs. A good place for sharing info. Believe me I’m getting more information than I can give at this time. Thanks to all who contribute.
Jon
-- Jon --Always remember, never live your life by a motto.
RussellAP
#15 posted 03-28-2013 03:01 PM
JOn, you’re right, there is a lot to learn about turning finials. I most likely don’t have the right tools so I’m looking into bulk HSS so I can mill my own.
