Shop Cabinet Dimensions
Forum topic by Matt Przybylski posted 03-25-2013 06:48 PM 3398 views 0 times favorited 3 replies Add to Favorites Watch
View Matt Przybylski's profile
Matt Przybylski
539 posts in 2254 days
03-25-2013 06:48 PM
Topic tags/keywords: carcase plywood cabinets construction shop storage
So I went to design some shop cabinets yesterday in SketchUp and while I have all the construction in mind I realized I never really thought about dimensions. I’m going to be creating a bank of lowers for my miter saw station and uppers to store some stuff. It’s all going to be 3/4” ply construction except the bottom of the cabinets will have a 2×4 frame inside where i’ll attach leg levelers since my garage floor is uneven. Here is what I was thinking for the lowers (probably about 4 of them in a row or 3 on one side, miter saw lowered tier, then 2 on the other, not sure yet):
What do you think of these sizes? Keep in mind that this is 35 1/2” tall which gives me a bit of room for 1/8” hardboard on top and a bit for the levelers on the bottom which will undoubtedly lift the cabinets up slightly off the ground. I’ll also be putting drawers in these so should i go wider? I want to use 22” full extension drawer slides and have maybe 3 – 4 drawers per case. Should I use 1/2” ply for the drawer boxes?
As for uppers I was thinking of making them 12” deep by 30” high by 24” wide.
I want to use sizes that will yield the least possible waste from the 4×8 sheets of ply but also will work/function properly.
-- Matt, Arizona, http://www.reintroducing.com
3 replies so far
View MrRon's profile
MrRon
4570 posts in 3119 days
#1 posted 03-25-2013 07:06 PM
The sizes are fine. What you need to do is make a layout of all the pieces including space for cut waste to see if it all can be cut from a 4×8 sheet. From there, you will be able to see where dimensional changes need to be made. I do this all the time when using sheet goods. I do layouts in autocad. I usually try to avoid even dimensions like 24 and 48 for repetitive pieces. You can’t get (4) 24×48 pieces from a 48×96 sheet, but you can get (4) 23-3/4×47-3/4 pieces.
Matt Przybylski
#2 posted 03-25-2013 09:12 PM
Gotcha MrRon. Also, one other thing I forgot to mention, should these (bottoms) have backs? And if so, can I do 1/2” backs? Since they’ll have drawers I’m not sure if backs are necessary but I suppose for the construction aspect of it they’d be good with backs, just not sure what size backs to use.
View Redoak49's profile (online now)
Redoak49
3017 posts in 1864 days
#3 posted 03-25-2013 11:50 PM
I built about 16 running feet of upper and lower cabinets. I made all of the cabinets 24” wide and 30” tall so that the material cuts out of a full sheet with very little waste. Like what you are saying, my bottoms were a combination of doors and drawers. The uppers were 12” deep, 24” wide and 30” tall. I used 3/4” Aruaco Plywood for the sides, top, and bottoms and then 1/2” for backs.
They were built with the Euro frameless style. I drilled the shelf holes also with Euro style with the 37 mm set back and 32 mm between holes. I did this so that the holes for the drawer slides and hinges fit in these holes. It made installing doors and hinges so easy.
I cut all of the parts and then finished them before assembly which was done with pocket screws.
After more than a year, I am still very happy with them. I really never want to do that much finishing again. It seemed like it took forever with hand brushing all of the parts.
Good luck with your project.
