Chisels for Powermatic 701 Hollow Chisel Mortiser
Forum topic by rockindavan posted 03-25-2013 05:23 PM 2759 views 0 times favorited 5 replies Add to Favorites Watch
View rockindavan's profile
rockindavan
299 posts in 2634 days
03-25-2013 05:23 PM
I’m planning to buy the 701 Powermatic mortiser and I need to get a set of chisels to get me started. Is there any specific bits that will/won’t work. I though I read somewhere that it requires long shank, but I’m not sure.
I plan on getting the economy Lee Valley hollow chisels, but I would like to know that they will work. In the future I will plan on getting better ones, but need a cheap set to get me going.
Any other recommendations in the $15-20/ chisel range?
5 replies so far
View ChuckC's profile
ChuckC
828 posts in 2933 days
#1 posted 03-25-2013 05:33 PM
I just bought this mortiser. It comes with 2 bushings so you can use 5/8” or 3/4” chisels. I went with Powermatic chisels. They are pricey but worth the money.
runswithscissors
2751 posts in 2023 days
#2 posted 03-25-2013 09:11 PM
I use the chisels that came with my Delta mortiser, which I suspect are not premium quality. But they work okay, and much better when sharpened and lubed. The lube (wax, or “Dry Lube”) is to help overcome friction when retracting the chisel. Helps also on the cut stroke. There is a cone shaped sanding tool that fits on a rubber cone shaped mandrel that is good for sharpening. Don’t know the brand, but Harbor Freight in Bellingham carries them. Only takes a minute or two with the cone sander chucked in a cordless drill. Then lap carefully to remove any burrs on the corners (you don’t want to change the profile). Because perfectly centering the mortise is always problematic, I run the stock through a second time after swapping ends on the board. Then cut the tenons to fit. Some people say you shouldn’t run the board twice, on the theory that the chisel will flex when only shaving one side of the mortise. But I have not found that to be a problem. Those chisels are very stiff.
runswithscissors
#3 posted 03-26-2013 04:18 AM
Oops! I goofed. Did not get my cone shaped sanding drum at HF, but at Hardware Sales in Bellingham. Next time I’m in there I’ll check the brand.
View Loren's profile
10390 posts in 3646 days
#4 posted 03-26-2013 04:21 AM
I have a lot of chisels that came with my Powermatic 719
when I bought it from a church that made their own
furniture when they expanded. I have more than I need.
I can sell you some. They are used but in good shape.
View RJ2's profile
RJ2
151 posts in 3783 days
#5 posted 04-18-2013 02:33 PM
downsizing my shop , and might have to be parting with my Powermatic Model 10 , it has a 5/8 chisel bushing, I lost and would like to find a place to purchase a 3/4 ” chisel bushing, since most of my chisels are that size. s
-- RJ, Tampa Fl, RJMETALWOODS.COM
