Does anyone know this Drill Press?
Forum topic by LittlePaw posted 03-25-2013 05:43 AM 3714 views 0 times favorited 22 replies Add to Favorites Watch
View LittlePaw's profile
LittlePaw
1571 posts in 3225 days
03-25-2013 05:43 AM
Topic tags/keywords: drill press
I bought this old drill press at an estate sale. It took two hefty guys to put it on my truck. It has no brand label. It has a cast iron (I think) hood protecting the belt pulleys. Everything works very smoothly after I did a little cleaning and oiling all the moving parts. The motor sounds a little strange – almost groaning. The weight of the motor is the tightener for the belt. There are five pulleys on either side, so it has 25 speeds settings, but there is no chart showing the speeds. 16 23 A are cast on the main post housing. Over all, it is a well built heavy duty drill press. Does the red/white/blue WAR FINISH painted sign indicate that it was made during WW II ? If it is, this d/p is over 68 years old! I would appreciate any information on this gentle giant, please.
-- LittlePAW - The sweetest sound in my shop, next to Mozart, is what a hand plane makes slicing a ribbon.
22 replies so far
View History's profile
History
399 posts in 2128 days
#1 posted 03-25-2013 05:47 AM
My guess would be either a Delta, or a Atlas.
View Woodknack's profile
Woodknack
12369 posts in 2526 days
#2 posted 03-25-2013 06:13 AM
My guess would be Canedy-Otto since that’s what it says on the label; 16 is probably the size in inches.
http://vintagemachinery.org/photoindex/detail.aspx?id=11465
View CalgaryGeoff's profile
CalgaryGeoff
937 posts in 2628 days
#3 posted 03-25-2013 06:23 AM
By the looks of the drill press it should last another 80 years at least. She is sure well built.
-- If you believe you can or can not do a thing, you are correct.
View Woodmaster1's profile (online now)
Woodmaster1
1045 posts in 2733 days
#4 posted 03-25-2013 06:53 AM
Looks similar to an old south bend I used to have in the metal shop at school.
View RonInOhio's profile
RonInOhio
721 posts in 3011 days
#5 posted 03-25-2013 07:23 AM
Canedy-Otto is correct. Established in 1889, dissolved in 1942 and revived for the war effort. The companies assets
were sold to Cincinnati Lathe & Tool Co. and lasted until 1956.
View kellyjones112's profile
kellyjones112
6 posts in 2069 days
#6 posted 03-25-2013 09:16 AM
See this model: Canedy-Otto Manufacturing Co.
http://vintagemachinery.org/photoindex/detail.aspx?id=15014
You may also find your likely model here, where Vintage Machinery Photo Index is a place where members of this site can submit photos of old woodworking machinery. The Index is a valuable resource in that visitors to this site can see examples of machinery made by many different manufacturers. :
vintagemachinery.org/mfgindex/detail.aspx?id=153&tab=4
Harwood flooring installer
View Bill White's profile
Bill White
5072 posts in 4107 days
#7 posted 03-25-2013 11:13 AM
Unless I’m WAY wrong, it only has the 5 speed settings. Ya can’t run belts “cocked” between pulleys with any success.
Bill
-- bill@magraphics.us
View johnstoneb's profile
johnstoneb
3014 posts in 2319 days
#8 posted 03-25-2013 12:30 PM
Bill X2
-- Bruce, Boise, ID
LittlePaw
#9 posted 03-25-2013 02:42 PM
Great info, Guys. Thanx a bunch. I’m going to check out that vintage site. The 5-speed limit sounds logical without testing it out. Now I don’t need to. Yup, this thing is exactly what people refer to when they say “they don’t make ‘em like they used to”! I’m going to clean it up, probably not repaint it as the original paint (finish) looks really good, and with the light use I do, it will last another 80 years – at least! Any idea what this unit might be worth?
View Lee Barker's profile
Lee Barker
2170 posts in 2997 days
#10 posted 03-25-2013 03:56 PM
Actually they’re worthless and that cast iron piece on top tends to explode during use.
Rather than have to go to the trouble of purchasing ballistic gear, head to toe, to wear when you’re using it, the wisest course of action would be to deliver it to my shop. I can take it from there.
Kindly,
History
#11 posted 03-25-2013 04:01 PM
It’s really hard to give a value on the machine without being there to really look it over. Is it a benchtop or floor standing drill press ? What size chuck does it have ? Then you mention that the motor sounds strange, have you tried running the motor without the belt ? What size motor is it ? Is it the original motor ? It is definately a neat old drill press, and I’m a sucker for old American made iron. I’ve brought a few machines back to life, they take time and sometimes a little money to get it as good as it’s going to get, but it’s well worth the time in my opinion. Nice gloatable score.
View Loren's profile
10477 posts in 3794 days
#12 posted 03-25-2013 04:10 PM
Nice one.
Some drill presses have an extended quill travel. Most are
around 3” but if you find one with more, it’s a less
common machine.
Info on “war finishes”: http://www.practicalmachinist.com/vb/antique-machinery-history/ot-what-war-finish-wwii-era-machine-tools-204218/
Woodknack
#13 posted 03-25-2013 04:28 PM
What would cause that Lee? Isn’t that cast iron piece just a cover?
LittlePaw
#14 posted 03-25-2013 04:38 PM
Wow, it’s getting more and more interesting by the minute! I’m gonna check out for you, Saw Sucker.
View DocSavage45's profile
DocSavage45
8699 posts in 2989 days
#15 posted 03-25-2013 05:19 PM
Paul,
May be bearings, or ? Sometimes older motors have lube cups? I’‘d see it runs smooth w/out the belts, but not too long? I checked to see about the motor on my grizzly with a motor repair place…65 per hour!
Might look around for older motors if it’s a problem?
Good luck. Haven’t seen a posting for your cane? Did I miss it?
-- Cau Haus Designs, Thomas J. Tieffenbacher
