any idea how I can secure the legs
Forum topic by Mark posted 03-24-2013 08:28 PM 793 views 0 times favorited 2 replies Add to Favorites Watch
View Mark's profile
Mark
964 posts in 2148 days
03-24-2013 08:28 PM
I’m making a mantle with a large top and 2 legs connected to a body. The top will be bolted from the under side through 2 bricks set at right angles to the brick facing (hope that makes sense). That’s the hatched pieces on the drawing. The question is how do I secure the legs and body to the fire place? I plan to have a recess in the top of the body that will slip up and in a piece on the top, it will fit but not be very secure. Thank you for any input.
-- Mark
2 replies so far
View mark4345's profile
mark4345
71 posts in 2596 days
#1 posted 03-24-2013 08:36 PM
I would attach a piece (either 2×4 or a built up lamination of plywood) to the fireplace with construction adhesive and tapcons to the facebrick. Then your legs of the mantle leave a recess in the back so the leg will slide over the 2×4/plywood lamination. either use trim screws through the side of the legs into the blocking or trim nails.
View weldoman's profile
weldoman
114 posts in 2231 days
#2 posted 03-24-2013 11:39 PM
Drill the brick behind the legs and body and glue in dowel rods, then screw the legs into dowels.
-- missouri, dave
