Electric motor swap question
Forum topic by coloradoHick posted 03-24-2013 09:16 AM 1000 views 0 times favorited 7 replies Add to Favorites Watch
View coloradoHick's profile
coloradoHick
1 post in 1885 days
03-24-2013 09:16 AM
Topic tags/keywords: electric motor swap hp rpm
Hey folks,
I am a newbie to the forum (and woodworking in general). I have recently scored a grizzly dust collector that no longer has the 3 HP motor, but does have everything else. I have a line on a 8 gallon air compressor with a 220v 5hp 3450 rpm 7/8” shaft magnetek motor that I think will work. It is more powerful, but other than that the specs line up. I am just wondering if the impeller will be too heavy (it mounts on the motor shaft), or if there are any other differences between an air compressor motor and a dust collector motor, or having the bigger motor will cause any problems with the unit.
I should add that I am a weekend warrior, and that this dust collector will not get the amount of hours that it would in a pro shop. And I have not wired it yet so I could obviously use the correct wire and breaker size for a 5 hp motor.
Thanks for the advice!
Jon
7 replies so far
View sprucegum's profile
sprucegum
324 posts in 1992 days
#1 posted 03-24-2013 10:58 AM
I would go for it if the motor is free or real cheap, but thats just me, I once helped a friend put a 327 in a WW2 jeep. A little more HP is always good rite?
-- A tube of calk and a gallon of paint will make a carpenter what he ain't
View Lee Barker's profile
Lee Barker
2170 posts in 2845 days
#2 posted 03-24-2013 12:44 PM
Welcome to the forum Jon. I hope it is helpful and inspirational for you.
It sounds like you’re attentive to the possible differences between the motors but I see no mention of mounting. The key things are shaft diameter and length, rpm and mounting. If you’ve got those covered, make the move!
Kindly,
4983 posts in 2488 days
#3 posted 03-24-2013 12:50 PM
Like Lee said, the mounting arrangement and the shaft size will be the key. For the record, I have a 5 HP compressor duty motor on my DC. It’s the same one that CV sells for their units…and that’s where I bought mine. But his one one is c-face, I’m guessing the one you need is a 56 frame or such.
Shawn Masterson
1325 posts in 1943 days
#4 posted 03-24-2013 01:23 PM
I will work as long as the shafts match
the only concern I have is that most compressor motor are an open frame and a DC should a sealed motor. you are sucking the dust to the impeller and any leaked dust will be sucked right into the motor, causing premature bearing and contact failure. It may last for a while not as long as it should. also I have noticed an influx of over rated motors. I had a “6.5hp” on my old compressor and there was possible way it was. It only drew 15 amps, a true 5HP should be around 22-25 amps. amp ratings are the best way to see how close a motor is to it’s rated HP.
View RussellAP's profile
RussellAP
3104 posts in 2281 days
#5 posted 03-24-2013 02:08 PM
A couple of basic things. Know the difference between a horizontal and a vertical motor and don’t mix them up. Some DC systems are extensive and will cause a motor with an efficient impeller to start very slowly due to back pressure. If the motor has start windings, and a centrifugal switch, it could heat up very rapidly on startup. I would think a capacitor start would be your best choice. Or maybe a system with a belt and a clutch.
View waho6o9's profile
waho6o9
8188 posts in 2572 days
#6 posted 03-24-2013 02:14 PM
Maybe get Grizzly tech support to give you some friendly advice
as well.
Welcome to LJ’s ColoradoHick!
runswithscissors
2750 posts in 2020 days
#7 posted 03-24-2013 09:24 PM
Typically compressor motors are very strong at startup, because they have to overcome existing pressure in the tank. That’s why many motors specify “not for compressor use.” I share Shawn’s concern about vulnerability to dust; but assuming the seal where shaft enters the impeller shroud is tight, it may not be such a problem.
