Have you tried the HF headlight lens restoring kit?
« back to Coffee Lounge forum
Forum topic by Lee Barker posted 03-23-2013 11:31 PM 915 views 0 times favorited 7 replies Add to Favorites Watch
View Lee Barker's profile
Lee Barker
2170 posts in 2818 days
03-23-2013 11:31 PM
It’s $30 to have a detail shop do it….just wondering if the DIY is the way to go.
Thanks for your help.
Kindly,
7 replies so far
View JoeinGa's profile
JoeinGa
7735 posts in 1974 days
#1 posted 03-23-2013 11:48 PM
If you’re talking about cleaning up the plastic lenses (that a lot of cars have) and how cloudy they get, save your money.
Believe it or not… THOOTHPASTE will polish them out. Wrap a rag around two fingers and use a swirling motion to apply the toothpaste. Just keep adding small amounts of the paste and rubbing it in. Polish it off with a soft cloth (like a t-shirt) every so often and you’ll be amazed how well it does.
View longgone's profile
longgone
5688 posts in 3276 days
#2 posted 03-24-2013 12:38 AM
I use plastic cleaner and polish that I got aw Wally Mart and it works just as good as the overpriced lens cleaning kits. It was cheap…only a few dollars…but it doesn’t prevent cavaties….
View troyercar00's profile
troyercar00
21 posts in 2856 days
#3 posted 03-24-2013 12:56 AM
If they are really faded, they can be sanded with 600 grit sandpaper until you get below the first layer (you will see it as you sand) and then polished with a buffer and polishing compound. If they are not real bad you can just buff with polishing compound by hand. I do this all the time as it is a fail (if bad enough) for PA vehicle inspections.
View Howie's profile
Howie
2656 posts in 2890 days
#4 posted 03-24-2013 01:40 AM
Lee, I tried the HF kit and it did work. However I don’t see why any of the above directives wouldn’t work. Think I’ll try one of those next as they are a lot cheaper. I like the toothpaste idea.
-- Life is good.
Lee Barker
#5 posted 03-24-2013 01:52 AM
Thank you for your wonderfully helpfull replies. I’ll go with the 2thpaste 1st. The lenses aren’t bad, just not right.
Kindly,
View DaleM's profile
DaleM
958 posts in 3351 days
#6 posted 03-24-2013 01:55 AM
I used Brasso metal polish that I already had and a cheap electric car buffer that I got at a yard sale. It worked great and went really quick. I imagine jewelers rouge or any of the other buffing/polishing compounds would work just as well as the Brasso.
-- Dale Manning, Carthage, NY
woodbutcherbynight
4346 posts in 2376 days
#7 posted 03-24-2013 02:59 AM
Don’t be surprised when they fade again no matter what you try. I have the kit at work, we do it for customers and it comes with 3 month warranty. Sucks I know but the issue is with the headlamps used on most newer cars and how the plastic degrades from the heat inside and out. And yes, I use it on my truck, usually holds for 6 months then hit it again.
