Door trim question
« back to Coffee Lounge forum
Forum topic by carguy460 posted 03-23-2013 04:49 PM 7097 views 0 times favorited 7 replies Add to Favorites Watch
View carguy460's profile
carguy460
802 posts in 2358 days
03-23-2013 04:49 PM
Not too sure where I should post this, so I’ll throw it in the off topic section…
I’m refinishing a basement room, and I’ve run into an issue. The old walls of the room were 1/4” paneling, which I removed and replaced with 1/2” drywall. The door for said room was not removed or repositioned, which leaves the door jamb 1/4” away from being flush with my drywall. How can I install trim/moulding around the door without there being a noticeable gap?
Maybe this picture helps?
If I was making my own molding I would just cut a rabbet out to accept the drywall, but I’m not planning to make my own trim for this room…
Oh, and caulk is not an answer as I would like to stain the trim, not paint it…
So…experts…any ideas?
-- Jason K
7 replies so far
View redSLED's profile
redSLED
790 posts in 1915 days
#1 posted 03-23-2013 05:32 PM
Don’t know if there’s a way to achieve a seamless all solid wood finished door trim job there with zero additional cost and minimal time. Cheap and fast: add to existing jamb 1/4”+ of trim/shims all around (use the leftover panelling if available), hand plane/file/sand down flush and install final trim/moulding of your/customer’s choice then stain/protect is all I can suggest.
View waho6o9's profile
waho6o9
8205 posts in 2599 days
#2 posted 03-23-2013 05:46 PM
Maybe install quarter round around the perimeter?
View EPJartisan's profile
EPJartisan
1118 posts in 3148 days
#3 posted 03-23-2013 07:09 PM
Due to my constant remodeling of my condo.. I have encountered this as well.. after I replaced a door frame with the best figrued cherry boards to match my hallway, then remodeled the bathroom… arg.. I did what James101 suggested.
-- " 'Truth' is like a beautiful flower, unique to each plant and to the season it blossoms ... 'Fact' is the root and leaf, allowing the plant grow and bloom again."
carguy460
#4 posted 03-23-2013 07:30 PM
Thanks guys…redsled, that had crossed my mind, as did James’ idea. I just didn’t know if that was legit and would work…and I hadn’t though of quarter round…hmmm…
So it looks like I’m not the first to do this…I think I may use a combo of James and sled’s plan. I don’t know what molding I’m using just yet, but I think the shim and notch plan may be best…and if it looks like crap, quarter round will save the day!
Thanks again guys!
-- Jason K
View Don W's profile
Don W
18754 posts in 2590 days
#5 posted 03-23-2013 08:37 PM
Just add a jamb extension. Rip a piece similar to the door jamb. Finish the edge butting to the door similar to what the door jamb is. Think of it almost like a mini v groove and fasten it to the door. I’d use small finish nails. Nail your trim up like you normally would.
carguy460
#6 posted 03-23-2013 09:22 PM
Jamb extension…thats a term that makes perfect sense to describe what I’m trying to do! Seems like everyone had the same general idea. Thanks again guys!
-- Jason K
View doordude's profile
doordude
1085 posts in 3005 days
#7 posted 03-24-2013 05:00 AM
carguy460, yes it’s called a jamb extention. usally 11/16” thick, if it’s an interior jamb. you just butt up against jamb, but hold back a 1/4” from jamb edge to leave a reveal. now this piece should be flush with sheet rock.then apply your standard trim, as normal.
