electrolysis question
Forum topic by HokieMojo posted 64 days ago 165 views 0 times favorited 8 replies Add to Favorites
View HokieMojo's profile
HokieMojo
414 posts in 265 days
64 days ago
Topic tags/keywords: electrolysis planes rust rust removal
I know there are some electrically inclined people here so I was hoping someone could give me some advice. I’m trying to use elctrolysis to clean up a handplane that I bought. All the examples I’ve seen say to use a battery charger but I don’t have one. Could I use one of those fist sized 6V batteries? If so, would the polarity be set up the same way (- attached to part to be cleaned, + attached to sacrificial anode)? Any assistance would be greatly appreciated.
Thanks!
View Randolph Torres's profile
Randolph Torres
105 posts in 65 days
64 days ago
Hokiemojo: ?Where did you hear of that process and did they mention voltage and amperage used if you use a battery you might not have enough amperage to complete the process. I remember when welding we would soak our glasses in a water vinegar solution to desolve the metal that stuck to the lenses, but if you will experiment on something else first some rusting thing you don’t care about. And wash thoroughly after the vinegar bath to neutralise. PS—The polarity would be the same. Randolph
-- another tip from cooperedpatterns
HokieMojo
64 days ago
Thanks for the info. I found the info on several site, but the idea to do this came from David's extremely helpful blog. I too am a bit concerned I’ll run out of juice to early, but I figure it might be worth a try. I tested this on two pieces of rebar (one to clean and one to sacrifice). I was getting decent amounts of bubbles, but it looked like the rust was so light I could wipe it off with a scotchbrite pad on both. As such, the experiment wasn’t all that helpful.
Has anyone else tried using batteries instead of chargers?
View SCOTSMAN's profile
SCOTSMAN
539 posts in 122 days
64 days ago
I have removed rust very sucessfully using this method an anode and a cathode – + from a battery charger with a tub full of water and a few tablespoons of lye or washing soda very cheap to buy if you want more details just ask.Alistair
HokieMojo
64 days ago
Thanks,
My battery method seems to be working. I just wanted to avoid plunking down 40-50 for a better charger. once i do that and factor in the cost of the plane on ebay, the shipping, the other ingredients, my time, etc., I’m awfully close to the price of buying a good plane new. That being said, all the materials would be reusable.
I guess I’m just being cheap.
View Joe Lyddon's profile
Joe Lyddon
170 posts in 589 days
63 days ago
Here are some links that may help you:
http://www.woodworkstuff.net/RustRemoval.html
In my experience, a simple battery would probably NOT last for the complete process… you’d have to try it… The polarity, etc. would be the same.
A cheap battery charger works really good!
The process works really well… if you don’t stop the process & continue on a few hours, it may damage the surface of your object…
A dramatic test would be to take something so heavily rusted that you can’t tell what it is… use it on this process… and see the unbelievable results obtained… It does really work.
-- Have Fun! Joe Lyddon - Home: http://www.WoodworkStuff.net ... My Small Gallery: http://www.ncwoodworker.net/pp/showgallery.php?cat=500&ppuser=1389"
View TimH's profile
TimH
10 posts in 69 days
63 days ago
I used this to clean some of the tools I recieved from my grandpap. It works pretty well. I used the powerpack from an old laptop computer, cut the plug in to the computer off and attached two alligator clips.
HokieMojo
63 days ago
Thanks for the link Joe. Some added info I hadn’t seen (like how to make your own washing soda from baking soda).
Well, I went with the battery and had the only the frog hooked up. It got it pretty clean. I think it could do more, but I didn’t want to leave the setup unattended so I took it out and cleaned it up as best I could with WD40 and a toothbrush (borrow a friends, you don’t want to use your own) lol. I think I’ll give it anotehr dunk in a few more days, but the wd40 will hopefully prevent the rust from returning until then. I guess I need to buy some real penetrating oil or something from an autobody shop. Any suggestions?
HokieMojo
63 days ago
I like that Idea TimH. I”ve got a few leftover power supplies for a desktop PC. This sounds like a real possibility.
Bookmark And Share This Page
