Can I Convert My Craftsman Table Saw Into Just A Router Table?
Forum topic by Jim Reeves posted 03-23-2013 03:07 PM 10902 views 0 times favorited 11 replies Add to Favorites Watch
View Jim Reeves's profile
Jim Reeves
208 posts in 2898 days
03-23-2013 03:07 PM
Hi, my question no dought seems like a weird one, I have a older craftsman table saw i will try to post a picture of tablesaw. Tablesaw has a good size top when new came with metal stand attached, about a year ago bought a better table saw not as large new craftsman has the extentions coming out when not in use takes up much less room and is 3hp.
It has room on right side to add a tablesaw insert, but i have 3 tablesaws, just use 2 of them.
So i thought for all i will get selling older craftsman table saw, maybe could convert it to a nice size router table.
I dont presently have a router table, wanted to buy the kreg precision router table my wife thinks is to much l disagree would love to have kreg full size precision table.
If anyone has any idea’s would love to hear them, only downfall would be the tablesaw takes up so much room not sure if insert could be set ireevesn new table saw where wings extend out.
In my shop pictures 2nd photo on left shows tablesaw not sure if well enough view ior not could post it here but if needed can take new picture of table saw post it here.
thanks jim
-- jim
11 replies so far
View JoeinGa's profile
JoeinGa
7732 posts in 1881 days
#1 posted 03-23-2013 03:47 PM
I’m sure it could be converted, and probably pretty easily. But is the saw still useable as a saw? If so, you might be able to sell it (Craigslist) and apply what you get towards the Kreg that you really want.
View Don W's profile
Don W
18563 posts in 2442 days
#2 posted 03-23-2013 03:57 PM
I thought about doing the same thing. After looking it over I concluded it was easier to just build a router table.
Something else I discovered in the process. Craftsman table saws don’t sell for much or very fast but dismantle it and list it piece by piece and watch it go. I’ve done it a couple of times and now and not only did I sell everything, but I had guys contacting me for weeks asking if I still had parts.
View toolie's profile
toolie
2101 posts in 2503 days
#3 posted 03-23-2013 04:12 PM
i’ve seen it done once. not sure if it was on this or another forum. if not here, check woodnet.net/forums or woodworkingtalk.com.
View Don Broussard's profile
Don Broussard
3422 posts in 2126 days
#4 posted 03-23-2013 04:17 PM
LJ sprucegum showed how he converted a table saw into a dedicated router table here.
-- People say I hammer like lightning. It's not that I'm fast -- it's that I never hit the same place twice!
View knotscott's profile
knotscott
7821 posts in 3250 days
#5 posted 03-23-2013 04:33 PM
I’ve heard of it being done. If you can figure a way to mount the router, you’re in.
View sprucegum's profile
sprucegum
324 posts in 1872 days
#6 posted 03-23-2013 05:48 PM
I did just that to my old delta and I posted it on LJ I am going to look up the post in a couple of min. I will comment on it to bring it up on top again and you guys can take a look. It involves a little very simple milling machine work. I did my own but almost every one has a machinest buddy who does government work on third shift.
-- A tube of calk and a gallon of paint will make a carpenter what he ain't
Don Broussard
#7 posted 03-23-2013 05:55 PM
@sprucegum—See Comment #4 above. Nice job of machining the top to accommodate the insert.
116813 posts in 3451 days
#8 posted 03-23-2013 05:56 PM
Don already posted it Sprucegum
Jim
even though sprucegum did a good conversion ,IMO your better off starting new. You can come up with the size top you want and have storage in the lower cabinet without having to do metal work.
View jack1's profile
jack1
2095 posts in 3901 days
#9 posted 03-23-2013 07:26 PM
I agree with Jim. Either buy a premade or build your own. I think you’d be happier.
View alfromelkhorn's profile
alfromelkhorn
1 post in 1442 days
#10 posted 02-08-2014 09:42 PM
I found this site by wondering the same thing. I had an old table saw, a new Triton Router, and the Table Mounting Plate. An engineer friend came over and we removed the motor and adjusting rods/gears from under the Table Saw. Then we marked off the space we needed to mount the Router and Plate taking full advantage of one of the Miter Gauge slots, Fence, and Off-Feed Extension.
The Table Plate is held into position by come angle iron fastened to the bottom of the table out of the way of the router, and the Table Plate is screwed into that. By removing the face plate on the front of the table saw, I have access to the adjustments on the router.
Now all I have to do is add some maple boards to the working side of the fence to accommodate my bits and keep the original metal fence away from the bit. I will also install some stops so the fence cannot move too far into the bit.
I hope this was helpful.
Al (alfromelkhorn@yahoo.com)
View mahdee's profile
mahdee
3831 posts in 1642 days
#11 posted 02-08-2014 10:03 PM
The older craftsmans have a cast iron top. It will be possible but s lot of work.
-- earthartandfoods.com
