dry time for 8/4 maple
Forum topic by Lumberpunk posted 03-23-2013 02:28 PM 1316 views 0 times favorited 15 replies Add to Favorites Watch
View Lumberpunk's profile
Lumberpunk
334 posts in 2332 days
03-23-2013 02:28 PM
Hi All,
I do not own a moisture meter.
I have a stack of dry 8/4 maple that was bought about 2 weeks ago, it has been sitting in my very dry (woodstove) kitchen for that time, wondering if anyone has any idea how long I need to leave it before I can work with it.
Thanks
Luke
-- If someone tells you you have enough tools and don't need any more, stop talking to them, you don't need that kind of negativity in your life.
15 replies so far
View Monte Pittman's profile
Monte Pittman
29220 posts in 2333 days
#1 posted 03-23-2013 03:21 PM
You bought it a couple weeks ago. More importantly, when was it cut? If you place your hand on them, do they feel cooler than room temperature? If so they are too wet to use.
Moisture meters are sold at most home improvement stores fairly cheap.
View Bill Davis's profile
Bill Davis
226 posts in 3919 days
#2 posted 03-23-2013 03:29 PM
“Ideas” would only be that – ideas without more information.
To provide an answer that has some validity need to know:
1. What was the original moisture content of the wood? (Too late to get that now but a meter would have given an approximation.)
2. What is the relative humidity where the wood is stored? (A simple inexpensive RH meter would be a valuable thing to have around and would get you close enough.)
3. What final moisture content do you want. (You didn’t say what you will use the wood for hence where the final destination of your project is but my guess is inside the house, yours or someone elses. How dry you want it depends on the average RH of its final resting place.)
Or without a meter you could use the ‘oven dry’ method and measure the actual MC. But you would still need the an accurate scale to weigh a test piece to know your location RH.
Maybe someone would offer a guess.
View Elizabeth's profile
Elizabeth
817 posts in 3138 days
#3 posted 03-23-2013 04:21 PM
Harbor Freight sells a cheap moisture meter that seems to work pretty well.
Lumberpunk
#4 posted 03-23-2013 09:58 PM
Thanks for your responses guys… I have ordered a MM… seems like the best solution.
The wood was milled quite some time ago I believe, bought from a reputable dealer in vancouver.
The wood will be used to make a table, dry environment.
View woodworker59's profile
woodworker59
560 posts in 2196 days
#5 posted 03-27-2013 03:03 AM
The general rule of thumb is one year of drying time for every inch of thickness.. so a 1 inch board cut and stickered properly would be dry enough to use for furniture in one year.. Most try to get it down to 10% or less moisture content, but sometimes that’s not a possibility.. Where I live in lovely New England, boards that have been stored in my shop for over a year after being dried for a year are never below 12%.. that’s just the relative moisture level in my shop.. unless I want to talk the wife into storing lumber in the living room, I have to deal with 12%.. so far no problems.. just saying.. I own a MM and anyone looking to build much furniture should own one.. there are a lot of wood dealers who will swear its dry enough for furniture when its 18% or higher..SO I don’t buy lumber from anyone without putting my meter on it.. better safe than spit or warped.. Papa
-- Papa...
View Moron's profile
Moron
5032 posts in 3888 days
#6 posted 03-27-2013 04:01 AM
I always error on the side of caution and encourage being proactive instead of reactive
I like 1 year per inch of thickness + a year so if its an inch thick is 2 years, 2 inches = 3 years
Every year it sits and ages, like fine wine and old cheese…….it only gets better
Lumberpunk
#7 posted 03-27-2013 05:14 AM
The wood is pretty dry already, moisture meter coming tomorrow.
Thanks Guys
View djwong's profile
djwong
176 posts in 3215 days
#8 posted 03-27-2013 05:46 AM
One trick I use with wet construction lumber to tell if it is dry, is to weigh it and keep weighing it every few months or so. When the weight stabilizes, I know that it has reached equilibrium with the shop environment. I just write the weight on the board to keep track.
-- David W. Cupertino, CA
Moron
#9 posted 03-27-2013 05:47 AM
I’m always somewhat perplexed at people, how they think that the stamp they buy to put on an envelope to mail to a friend,and include the cost of a birthday card, think they can suddenly buy the same “Wal Mart” moisture meter for a few bucks more, then the price of a stamp and birthday card, and think…………”wow”…….she’s ready ?…cause the moisture meter said so
For some insane reason
I dont think so ?
Moron
#10 posted 03-27-2013 05:55 AM
like a fine wine and old cheese
wood gains patience with time and like a fine wine, either loosing its anger and tension or releasing its propensity to steel thus calming its nerves, either way,
it eventually teaches patience
View Wdwerker's profile
Wdwerker
333 posts in 2228 days
#11 posted 03-27-2013 06:16 AM
Weight does work well if you have an accurate scale. Read the instructions on your moisture meter, you may have to apply a correction factor depending on the type of wood being measured.
-- Fine Custom Woodwork since 1978
Moron
#12 posted 03-27-2013 06:33 AM
High school math
memories of
C’s and D’s for 9 years in 1st grade
weigh it
before it goes into the oven
and when it leaves
the rest is simple math and observation of reaction over time
View RonInOhio's profile
RonInOhio
721 posts in 2859 days
#13 posted 03-27-2013 06:44 AM
”One trick I use with wet construction lumber to tell if it is dry, is to weigh it and keep weighing it every few months or so. When the weight stabilizes, I know that it has reached equilibrium with the shop environment. I just write the weight on the board to keep track.”
Thanks djwong. That really does make a lot sense.
Moron
#14 posted 03-27-2013 06:50 AM
math
coming to Ohio soon
View Loren's profile
10377 posts in 3643 days
#15 posted 03-27-2013 06:58 AM
A guy showed me how you can lay the soft skin of your
forearm against a piece of skip planed lumber. If it
feels chilly, it’s not dry enough for furniture.
