Which way is better?
« back to Woodturning forum
Forum topic by RussellAP posted 03-22-2013 11:26 PM 826 views 0 times favorited 10 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
3103 posts in 2250 days
03-22-2013 11:26 PM
The knob is acrylic. I have about 8 of them in various colors and some very very exotic woods.
So do you think it’s better with or without and should I just trim off the wood part of the handle and glue the new handle to that?
10 replies so far
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 2036 days
#1 posted 03-22-2013 11:30 PM
I don’t like it personally. I like the look of picture number two as it is. Sorry bout the edit, so to be specific, I like the way the small wood part mirrors the bottom section, or bowl it’self, without being a mirror image, and also feels like a gives a feeling of symmetry top to bottom, enhancing the a symmetry of the center section of the lid.
That is the non-turner opinion here. Like the addition of the lid though. (if’n that is the “dog bowl”)?
-- Who is John Galt?
View kdc68's profile
kdc68
2649 posts in 2240 days
#2 posted 03-22-2013 11:37 PM
I like the acrylic knob myself…and trim the wood part off as you suggest….good save of the a.k.a. “dog bowl” that people commented on from your previous forum
-- Measure "at least" twice and cut once
View Grandpa's profile
Grandpa
3259 posts in 2639 days
#3 posted 03-22-2013 11:40 PM
The acrylic doesn’t add much but the second without the acrylic knob is…..well the knob is too short. It needs more.
joeyinsouthaustin
#4 posted 03-22-2013 11:44 PM
Grampa ”.well the knob is too short. It needs more.”
I agree,, maybe same form, but a little taller to be proportionate to the bowl it echos on bottom
RussellAP
#5 posted 03-22-2013 11:49 PM
I’m having a hard time holding the acrylic in place and even harder time cutting it. Is there some trick to turning it?
Grandpa
#6 posted 03-22-2013 11:51 PM
Yeah, just a little more. It is sorta short and stumpy if you understand what I am saying. No offense anyone.
woodbutcherbynight
4335 posts in 2373 days
#7 posted 03-23-2013 12:10 AM
RussellAP for pens I found cutting acrylic to require slower speeds. It is closer to working metal on a lathe than wood. It will sag when it gets hot from turning too fast and trying to remove too much at one time. Corian is much easier to work with as it will take the speed and heat better but it is harder than acrylic. Hope this helps.
RussellAP
#8 posted 03-23-2013 12:23 AM
woodbutcherbynight, I was turning it too fast then. It seemed to kind of bubble off onto the tool or chip in tiny chips.
View RonInOhio's profile
RonInOhio
721 posts in 2828 days
#9 posted 03-23-2013 12:28 AM
#2 looks better.
woodbutcherbynight
#10 posted 03-23-2013 02:57 AM
RussellAP, yup I found that out first time I tried it and it melted to the mandrel. I prefer Corian as it is easier and can be cut at same speed as wood. Kinda chips until you get it rounded. I will admit it is slow going after tha as you slolwy bring it down. I try to cut the blank to the smallest square I can get without blowout when I drill the hole for the brass tubes. If you want some Corian about 2” square and 1/2 thick drop a line I will send you some. The stuff is easy to glue together with CA and it blends without a line when turned. I have some nice granite green might look good with this.
