cutting angles in long pieces of wood?
Forum topic by tomtom1 posted 03-22-2013 08:41 PM 10798 views 0 times favorited 9 replies Add to Favorites Watch
View tomtom1's profile
tomtom1
7 posts in 1899 days
03-22-2013 08:41 PM
Topic tags/keywords: question shaping milling
hi I was just wondering what is the best tool to cut angles in long pieces of wood some plans I have want me to cut an 8 degree angle along 48 inches or 1291.2mm of wood as part of the top of a cleat!
The same plans also require a 20 degree cut along another length
Thanks
tom
9 replies so far
View Kaleb the Swede's profile
Kaleb the Swede
1833 posts in 1967 days
#1 posted 03-22-2013 08:46 PM
You have a number of possibilities. First you can buy a good straight edge like a BORA clamp that lets you turn it on an angle and cut along it with a jig saw or hand saw (depending on what your flavor is). Or you can save some money and clamp something nice and straight to the board on either side and make the cut that way. I did the long angle I had to do with a straight piece of MDF, two clamps and a jig saw. I then cleaned it up with a flush router bit, and I have also cleaned one with a hand plane. You can also make a tapering jig (look at Charlesneilwoodworking.com for plans for one, he is one of my idols, he has videos on it and free plans for it) and cut it on the table saw. Just take your time. I practiced first on a few scrap pieces of plywood and when I was happy I made the cut. Have fun.
-- Just trying to build something beautiful
404 - Not Found
2544 posts in 2967 days
#2 posted 03-22-2013 08:50 PM
Beveled edges for cleats?
Table saw or if you haven’t got a table saw, just plane it.
If you want to taper a piece, make a taper jig as suggested
View nwbusa's profile
nwbusa
1021 posts in 2284 days
#3 posted 03-22-2013 08:51 PM
It’s not clear if you’re trying to cut a bevel angle on the edge of a board (as for a French cleat) or if you want to make an angled cut to a board (i.e. making one edge non-parallel to the opposite edge).
For the first, a table saw is the best tool. Set the bevel angle on the blade and rip.
For the second, you have options as stated above by Kaleb.
-- John, BC, Canada
tomtom1
#4 posted 03-22-2013 10:01 PM
hey guys it’s the 8 degree cut that runs along the side in the top right of that drawing that shows a slight angle.. not the one marked with 20 degrees
View SamuraiSaw's profile
SamuraiSaw
515 posts in 1962 days
#5 posted 03-22-2013 10:24 PM
Given the piece is only 1 1/4” wide, a table saw is your safest and most convenient tool for a 8 deg bevel along that length. I wouldn’t use a circular saw on something that narrow.
-- Artisan Woodworks of Texas.... www.awwtx.com
View Jim Finn's profile
Jim Finn
2656 posts in 2920 days
#6 posted 03-22-2013 11:01 PM
Table saw or jointer is what I would use.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
tomtom1
#7 posted 03-23-2013 12:41 PM
Thanks All!
can a table saw do such a small angle? I was looking at this kind of table saw i know it’s small but im only going to be doing small projects!
any idea with the cleat with the angles in that photo how the end cleats would attach? i.e. the ones in the bottom of the drawing on the far right hand side? do you think they’d attach to the head and foot of the cradle?
tom
SamuraiSaw
#8 posted 03-23-2013 01:01 PM
Tom,
A table saw will do any angle (in this example really a bevel) from zero to 45 degrees. It is one of the strong points of the machine. Do some reading on here about contractor table saws. Even though you’re looking at small projects, a larger saw would be a much better investment. I’d highly recommend you avoid bench top tools, especially bench top table saws.
View Ken90712's profile
Ken90712
17556 posts in 3187 days
#9 posted 03-23-2013 01:08 PM
I agree with the others here Table Saw or Jointer will work. I would use the table saw though.
