Craftsman Professional 10” Model #152.221240
Forum topic by Kahr posted 03-22-2013 08:44 AM 3711 views 0 times favorited 2 replies Add to Favorites Watch
View Kahr's profile
Kahr
10 posts in 2127 days
03-22-2013 08:44 AM
Topic tags/keywords: 152221240 tablesaw
I have a Craftsman Professional 10” Model #152.221240 that is wired for 110 currently. I would like to change to 240.
Does anyone have this saw running on 240?
Thanks
2 replies so far
View knotscott's profile
knotscott
8174 posts in 3611 days
#1 posted 03-22-2013 09:40 AM
I had that saw on 240v (aka 220v) for over 3 years. In my case, switching to 240v made a notable difference in startup and recovery speed, which helped it plow through thicker materials with less bogging. There are no guarantees that yours will respond the same, depending on your supply circuit. If you have 240v available, all you’ll need to do is change the plug to fit your 240v outlet, and follow the schematic inside the wire junction box….it takes about 5 minutes for the rewire. It ran great with good 3/32” thin kerk blades.
You can also gain some rip capacity pretty easily on that saw if you want to.
View Kahr's profile
Kahr
#2 posted 03-22-2013 07:13 PM
Thanks for the information. I am just getting started and can use all the help I can get.
