Rough cast iron table saw top
Forum topic by boroughdan posted 03-22-2013 12:18 AM 3418 views 0 times favorited 33 replies Add to Favorites Watch
View boroughdan's profile
boroughdan
22 posts in 2143 days
03-22-2013 12:18 AM
Topic tags/keywords: question
I am looking into upgrading my table saw from my black friday $89 special to something a bit more substantial. I was thinking I would be in the $1000 range as an intermediary before I moved on to a ~$3000 cabinet saw in a few years. I came across the Ridgid r4512 and have seen lots of good reviews on it saying it beats out saws costing a few hundred more. I went today to take a look at the one at my Home Depot and because of their terrible desplay (up on a shelf at eye level) I couldn’t really play around with it.
That aside one thing I could tell was that the cast iron top wasn’t what I was expecting. I was expecting a smooth top and this was gritty. It seems like the wood wouldnt slide very easily on a top like that. Can anyone clear this up for me.
Also if anyone has another suggestion for a saw in that $500-$1000 range I would love to hear it.
33 replies so far
View MT_Stringer's profile
MT_Stringer
3183 posts in 3432 days
#1 posted 03-22-2013 12:30 AM
Check the “Reviews” section under table saws for some feedback from owners who have them. Hope this helps.
Mike
View Dakkar's profile
Dakkar
349 posts in 2129 days
#2 posted 03-22-2013 12:34 AM
Unless you need something ASAP, I definitely suggest starting a Craigslist watch (as well as other local classifieds). You could get a lot more saw for your money if you educate yourself on your needs and how to check out a used unit. When I’m watching for something I check it 2-3 times a day and try to contact as quick as possible. The great deals don’t last for long.
View darthford's profile
darthford
612 posts in 2125 days
#3 posted 03-22-2013 12:42 AM
Grizzly 1023. I had a Rigid with cast iron wings, a bit under powered but for a $600 saw it was a good value. I just finished assembling a new Powermatic PM2000 and was underwhelmed by a number of things frankly. No more mirror finishes on the PM saw tables, the ground finish was nothing special imo. Table and wings are absolutely flat however which is more important. Not one damn thing on the saw was aligned, blade to miter slot way out, 90 degree stop way off, fence off, errors in the assembly instructions, wrong size bolts for the rear rail I had to go buy a bunch myself, couple of shipping rub damage spots. Assuming the Grizzly is flat and true I don’t see how this Powermatic is worth $1,500-$2,000 more than the Grizzly.
View kdc68's profile
kdc68
2691 posts in 2478 days
#4 posted 03-22-2013 01:16 AM
boroughdan -Knottscott has a ton of great info on this site pertaining to the table saw. You can find posts with his info in most all forums regarding table saws
-- Measure "at least" twice and cut once
View crank49's profile
crank49
4032 posts in 3172 days
#5 posted 03-22-2013 01:24 AM
I have a Craftsman 21833 which is identical to the Ridgid 4512. If you go this way that’s fine as long as you understand you will have to replace it in a few years. And, you may have to replace it as soon as you get it home and put it together.
You must assemble this saw and check for a defect several of them have. When you raise the blade it will shift from one side to the other. What this is doing is throwing the blade to miter slot alignment out. If you have one of these saws with this defect it must be returned to the store for a refund or exchange. The problem is not fixable. I know because my saw has this problem and I didn’t think it was anything more than needing a little adjustment. WRONG. You can adjust it perfect, but the first time you change blade height your alignment just flew out the window.
Really too bad, because these are nice saws for the money. BUT, If I had it to do over I would go used from Craig’s list. I’ve seen some $3000 cabinet saws, unused and on the original shipping pallet, sell for less than $1000 on Craig’s list. Just have to be patient.
View Loren's profile
10477 posts in 3849 days
#6 posted 03-22-2013 01:26 AM
Actually wood slides better on Blanchard ground surfaces. If
a table is ground exceptionally fine and flat the there can
be a suction effect. Some guys who’ve had wide jointers
reground with a Blanchard grind can say that the wood
slides better. Air can get in between the wood and
the iron and this is a good thing.
View shampeon's profile
shampeon
1885 posts in 2385 days
#7 posted 03-22-2013 01:38 AM
Do a search on Craigslist for “unisaw” and my guess is you’ll find a good cabinet saw for less than a grand. I’m partial to the art deco models, but I see good condition Unisaws routinely for $300-700.
View Bruce Taylor's profile
Bruce Taylor
21 posts in 2139 days
#8 posted 03-22-2013 01:39 AM
You don’t say how much the R4512 is going to cost you but I found one at my local HD sale of rental equipment for $225 including a new 60T blade that I wanted. When I called my local tool repair guy and gave him the serial number, he said ‘buy it’. Apparently, it is in the last Ridgid table saw series with a lifetime warranty. So, I bought it and after a bit of tweeking, it is working like a champ. It even came with a fold-down dolly that is plenty strong.
-- Captain Bruce, Washington State
View jonwright's profile
jonwright
68 posts in 2138 days
#9 posted 03-22-2013 02:37 AM
I have a Craftsman 21833 which is identical to the Ridgid 4512. If you go this way that’s fine as long as you You must assemble this saw and check for a defect several of them have. When you raise the blade it will shift from one side to the other. What this is doing is throwing the blade to miter slot alignment out. If you have one of these saws with this defect it must be returned to the store for a refund or exchange. The problem is not fixable. I know because my saw has this problem and I didn’t think it was anything more than needing a little adjustment. WRONG. You can adjust it perfect, but the first time you change blade height your alignment just flew out the window.
+1 on this one. I had read where they thought the problem was long ago and the stock is now “fixed”. bought mine in January. Took it back. Also the fence is rather flimsy so when you adjust it you need to make sure it’s still square to the blade. Besides the aforementioned alignment woes my fence drifted.
And then I really got mad when I attempted to put a 3/4” sheet MDF on the saw and it tipped over (yeah, after I’d already sized it down with a circular saw and a straight edge). Newbie mistake, OK – but that’s when I realized what I wanted out of my saw this one wasn’t going to deliver – ever.
But…if you get an R4512 that’s STRAIGHT and you are patient and meticulous by double checking your alignment it can work. Many folks do fine projects with contractor saws. Some of them may need to clean up their lines with hand planes or more sanding.
There are a few other choices, however, in your price range that should, by my research, give you a decent saw.
Griz has a special going on now on the G0690, so that’s close. I mean, for another $400 you’d be DONE and not have any excuses or compromises and won’t need to upgrade to a $3k saw unless you just wanted to. Also the Craftsman hybrid saw gets nice reviews, and I THINK Steel city has some decent hybrid saws that fit your budget as well. For that cash you’re also playing in Saw Stop’s contractor model, too.
After being so effed off and disappointed with my experience I decided I was either going to play deep or go home. I really started to understand why folks kept mentioning cabinet saw for consistent cuts and stretched my budget and bought one.
Patience, a willingness to travel, and lots of research can yield a CL find. But when it comes along you better have the cash and jump quickly. Bring your straight edge and square to make sure it’s aligned and OK. I’m sure there’s a bunch of tips on checking out used equipment.
View toolie's profile
toolie
2148 posts in 2830 days
#10 posted 03-22-2013 02:49 AM
unfortunately, i believe this is absolutely untrue. to the best of my knowledge, no ridgid 4512 possessed a lifetime guaranty. the last ridgid stationary power tools that carried lifetime guaranties against manufacturing defects were gray in color, built by emerson electric for ridgid and predated the shift in manufacturing of the 3650/60 series TSs to one world technologies. what documentation was provided with the saw that supports that 4512 having a lifetime guaranty?
it may, if you are considered the original owner, qualify for registration with ridgid’s lifetime service agreement (LSA). here is ridgid’s current info on warranties and the LSA:
http://www.ridgid.com/tools/power-tool-warranty
boroughdan…........should you wish to pursue a 4512, try to find a HD that will honor harbor freight’s “25% off any single item” coupon. that $500 saw might be had for $375, which, iMHO, would be an extremely good deal for a 1.5 hp, dual voltage, left tilt, 30” rip capacity, CI TS with a built in mobile base, a 90 satisfaction guaranty, a 3 year new tool guaranty and eligibility for the original owner to register it with the LSA.
BTW,the gritty finish on the 4512 you saw is not indicative of the finish of the saw. whenever i’ve seen them in HDs, they are as smooth as any other CI top. and those saws are not treated terribly well by customers or the store staff. with a 90 day satisfaction guaranty, you can always bring it back if you’re not happy with it. not many other brands offer that.
Bruce Taylor
#11 posted 03-22-2013 03:20 AM
Hi Toolie,
Have to say that I took the word of my tool repair guy on the lifetime warranty issue but, having said that and having spent a couple of hours setting the saw up, I have absolutely no complaints.
View RogerInColorado's profile
RogerInColorado
321 posts in 2156 days
#12 posted 03-22-2013 03:37 AM
I’m in the camp of those who suggest patiently waiting for the right deal on craigslist and then pursuing it aggressively. I often see good Powermatic and Delta and Grizzly saws at bargain prices. Yes, there is also crap offered at diamond prices, but bargains exist and you can easily end up with a better used cabinet saw for what you would have paid for a new contractor saw.
View DKV's profile
DKV
3940 posts in 2705 days
#13 posted 03-22-2013 03:38 AM
The best saw to get if FITB is not an option is the FITB which took top honors at the recent FITB? However is FITB is an option then listen to what the LJs say and flip a coin. If it’s FITB then go for it. Otherwise you may want to consider the top of the line FITB which in all tests of FITB came out far ahead of the others. Holy shitoly man, don’t listen to anybody but your heart.
-- This is a Troll Free zone.
toolie
#14 posted 03-22-2013 01:36 PM
anyone know what “FITB” refers to?
View dhazelton's profile
dhazelton
2793 posts in 2498 days
#15 posted 03-22-2013 02:19 PM
I would buy the $3000 saw now used for $1000. When you try to sell the $1000 saw you are sure you’ll grow out of it will only bring you $500.
showing 1 through 15 of 33 replies
