Question for DMT users
« back to Hand Tools forum
Forum topic by Marty5965 posted 03-21-2013 06:43 PM 1357 views 0 times favorited 8 replies Add to Favorites Watch
View Marty5965's profile
Marty5965
158 posts in 1945 days
03-21-2013 06:43 PM
Topic tags/keywords: sharpening dmt diamodn stones
Hi Guys,
I scored a couple of hand planes (my first) off Ebay and started fettling them after watching about a thousand videos and reading almost every post on here about it.
When I got to the iron I realized that my 2” Spydercos, which work great on my chisels, were way to small to do a full size plane iron. So I bit the bullet and bought a couple more DMT diamond stones. After it took over an hour to establish the primary bevel on the course DMT I use to true my ceramics I knew I needed more. I now have the full set, extra course to extra, extra fine.
The irons are now razor sharp, but I don’t get the mirror finish that I get from my Spyderco ceramics.
Is this normal, or am I doing something wrong?
-- Marty, Columbus, OH, learning every day....
8 replies so far
View Kreegan's profile
Kreegan
1452 posts in 2146 days
#1 posted 03-21-2013 07:16 PM
I finish off with a leather strop charged with green chromium oxide honing compound after my DMT stones. That gets my mirror polish. That step isn’t really necessary. If they’re razor sharp, then they’re good to go.
View Don W's profile
Don W
18715 posts in 2567 days
#2 posted 03-21-2013 07:53 PM
Take a look at this, http://lumberjocks.com/donwilwol/blog/33653
Edit. One more note, the extra extra fine is the 3 micron. Did you get that one? If not, you probably should, or something equalvant.
Marty5965
#3 posted 03-21-2013 08:57 PM
Hi Don, somehow I missed that post, interesting. My top stone says extra, extra fine, which I believe is the equivalent of 8000 grit. I am wondering if I am being too aggressive and pressing too hard.
View BerBer5985's profile
BerBer5985
445 posts in 2420 days
#4 posted 03-21-2013 09:01 PM
I use the Paul Sellers method, Coarse, Medium, Fine (240,600, 1200) then leather strop charged with green stuff from Veritas. Mirror finish every time and with approx 30 sec worth of sharpening. Shaves hair like a razor. Check out paulsellers.com and see if you can’t find the video on the site.
-- Greg, Owner, Quality Carpet One, www.qualitycarpetonecrofton.com
View sikrap's profile
sikrap
1121 posts in 3358 days
#5 posted 03-21-2013 10:34 PM
Personally, I think we get too caught up with the mirror finish. I can use 2000 grit wet/dry sand paper and get a mirror finish, but its not as sharp as coming off my 13,000 grit stone which leaves a cloudy finish. IME, using water (or any lubricant) tends to leave a cloudy finish.
-- Dave, Colonie, NY
Marty5965
#6 posted 03-22-2013 01:06 AM
@Berber. Yes, I have seen him do that. I suspect my problem was that I was too impatient trying to get the primary bevel on and went too hard with the extra course. When I look at the bevel though a magnifying glass it’s almost as if there are feint scratches under the shiny part. Anyway, it shaves hair off my arm and I expect it to get better each time I hone it. Never had that problem with my ceramics, you can go as hard as you like.
View SamuraiSaw's profile
SamuraiSaw
515 posts in 1964 days
#7 posted 03-22-2013 01:32 AM
Marty,
I have the same stuff from DMT. I’ve been told they still need to be broken in even though DMT says they are ready. I typically follow up with a 8000 grit waterstone to get the mirror finish.
-- Artisan Woodworks of Texas.... www.awwtx.com
View Mosquito's profile
Mosquito
9305 posts in 2292 days
#8 posted 03-22-2013 01:37 AM
I was seeing the same results as you Marty. I would go through the range of DMTs (I had the same set as you, x-coarse through x-x-fine). I never quite got the mirror polish I wanted, even if the difference was purely in my head. I ended up getting a 6000 grit waterstone to finish with instead of the x-x-fine DMT, and am getting the mirror polish I was hoping for. The edge that comes off the x-x-fine is still very good, mind you, I just wanted mirror polish, I guess.
-- Mos - Twin Cities, MN - http://www.youtube.com/MosquitoMods - http://www.TheModsquito.com
