| Forum topic by BeechPilotBarry | posted 65 days ago | 215 views | 0 times favorited | 11 replies | ![]() |
65 days ago |
I’m in the process of installing a new dust collector. The unit came with a magnetic switch. The magnetic switch prevents me from using a Long Ranger remote. I’ve located a reasonably priced, PROPERLY RATED, non-magnetic switch. I could also replace the switch with a proper breaker and housing, as the remote can function as the switch. I can appreciate the value of a mag switch on a tool where a breaker could trip during an operation, and the operator resets the breaker without turning the tool off. I don’t see the value on a dust collector. I really want to use a remote with the DC. Anyone see a downside of me swapping out the switch? -- - Real men read directions |
65 days ago |
you don’t need a dust collector just belch one of those out like inthe picture it will flash off any saw dust in the air. Randolph -- another tip from cooperedpatterns |
65 days ago |
Hi Barry; I would want to do it as well, but have to wonder why the mfg chose to use one. Lee -- by Lee A. Jesberger http://www.prowoodworkingtips.com http://www.ezee-feed.com |
65 days ago |
My guess is that the magnetic switch is a legal thing. As long as the ratings for current/voltage are the same and the same configuration (SPST or DPDT) I would think it should work fine. |
65 days ago |
magnetic switches are safer, but if your remote system resets to off after a power outage, you should have no trouble. -- making sawdust.... |
64 days ago |
I’d do it also. It seems strange the the MFG put one in. I don’t see a safety issue with a dust collector like a jointer, saw or planer would represent. -- Karson Southern Delaware karson_morrison@bigfoot.com |
64 days ago |
This isn’t 3 phase by any chance is it? or a really big motor?? -- Fred, Springfield, Ma |
64 days ago |
More details – the DC, a JDS 3100-CK, has a 3HP 240v single phase motor. Max draw is ~ 18a, it came with a 240v/20A plug installed. Here’s my plan: My DJ-20 does not have a mag switch. Even though the DJ-20 is only a 1 1/2 HP motor, the same switch is used on the 3HP Unisaw, so I know the switch should be properly rated. I plan on swapping the mag switch to the DJ-20 and using the non-mag switch on the DC. The only rub, one that occurred to me last night, is that this DC has a second motor that “stir cleans” the air filter. I need to learn how this interfaces in the switch before I can move it. There may be some sort of timing device inside the mag switch. I may also be able to wire the output of the Long Ranger into the mag switch to properly operate the internals. Plan “B” is to possibly relocate the mag switch away from the DC, in an easily accessible area, but I’ve really gotten used to the remote. On a side note… the 120v Long Ranger works GREAT with HVLP turbines, too! -- - Real men read directions |
64 days ago |
I’d be interested in how you solve this. It might just be a good idea to call the people that made your dust collecter and see what they have to say. -- Only the Shadow knows.................... |
64 days ago |
I’m electrically savvy, so I buzzed out the leads today. There is a 240v timer, set to 1 minute that runs the filter beater. The timer is a socketed device, which made buzzing the leads much easier with an open circuit. I identified the pull-up (ON button) and knock-down (OFF button) relay leads. Both only deal with 120v, so I don’t think inserting a relay would be that difficult. I could insert a relay, operated by the Long Ranger, with an early-make contact on the knock-down lead, and a make contact on the pull-up lead, and leave the input 240v hot. Both relay contacts would break if the LR was turned off. This should act like someone pushed the on and off buttons and still provide power to the stir motor. The 240v timer is powered from the hot side of the switch. “EE”, you here? <g> If so, does it make sense to you? -- - Real men read directions |
63 days ago |
Barry, -- Loving what I do, while I do it for Christ ! |
63 days ago |
Les, I’d rather stir the motor myself instead of giving up the remote. To what John told you, when you push the off button, the 1 minute timer is activated. The timer is powered from the 240v “hot” side of the switch. My latest, simple, idea, is this: Swap the switch with my DJ-20, and use a 240v Long Ranger on the DC. Remove the timer and socket from the mag switch housing and wire it into a separate box that contains 240v all the time, and add an appropriate switch (probably momentary, but I’ll have to explore this) to activate the timer manually. I’ll then reuse the mag switch, minus the timer, on my DJ-20. You could even ditch the timer and simply manually turn the stir motor on and off with another 240v switch. I think this is better than trying to rig a relay to do it all automatically. -- - Real men read directions |
| Sponsor | Forum | Topics |
| Become a sponsor |
Woodworking Skill Share
1363 |
| Become a sponsor |
1809 |
| Become a sponsor |
124 |
| Become a sponsor |
378 |
| Become a sponsor |
111 |
| Become a sponsor |
Woodworking Trade & Swap
252 |
| Become a sponsor |
Coffee Lounge
1019 |
| Become a sponsor |
LumberJocks.com Site Feedback
286 |
