Unusual door hinge?
Forum topic by NewfieDan posted 03-20-2013 10:49 PM 1139 views 0 times favorited 4 replies Add to Favorites Watch
View NewfieDan's profile
NewfieDan
50 posts in 2524 days
03-20-2013 10:49 PM
I want to put in 2 doors in my gazebo. The opening is about 69”wide so I will be using 2 doors and trim them down slightly. My problem is that the posts that I have to mount the door hinges to are not square to each other. These are structural supports so I can’t change their position. What type of hinge will work for me? I need the doors to swing outward.
I also can’t change the door position because I have custom sized glass panels in place of traditional spindles. This also wouldn’t change the fact that the posts are not square to each other, because it is a 10 sided shape.
How can I mount the doors? I want to use doors for ease of access and to keep cats out of it. There are a couple of male cats that spray. I DEFINiTELY want to keep the male cats out.
Because of our fluctuating temps in winter I don’t want to drill into concrete base because of the thaw/freeze cycles.
16272 posts in 4094 days
#1 posted 03-21-2013 12:04 AM
What about mounting angled shims to the posts so that you have two mounting surfaces that are square to each other?
404 - Not Found
2544 posts in 2845 days
#2 posted 03-21-2013 12:23 AM
Make a door frame that fits around the posts?
View JJohnston's profile
JJohnston
1622 posts in 3167 days
#3 posted 03-21-2013 12:30 AM
Get the cats fixed?
Anyway, added-on bevelled jambs were my first thought, same as Charlie.
-- "A man may conduct himself well in both adversity and good fortune, but if you want to test his character, give him power." - Abraham Lincoln
View madts's profile
madts
1833 posts in 2215 days
#4 posted 03-21-2013 12:41 AM
I agree with renners.
-- Thor and Odin are still the greatest of Gods.
