Brad Point Drill Bit Set
Forum topic by Peteyb posted 03-20-2013 08:54 PM 3081 views 0 times favorited 16 replies Add to Favorites Watch
View Peteyb's profile
Peteyb
131 posts in 2672 days
03-20-2013 08:54 PM
Topic tags/keywords: brad point dril bits
I am purchasing a Drill press here shortly and wanting to get a nice set of brad point drill bits. I am wondering what would be a good set to last a long time.
16 replies so far
View nwbusa's profile
nwbusa
1021 posts in 2403 days
#1 posted 03-20-2013 09:02 PM
This is a very nice HSS set from Lee Valley.
I also have a few of these, for drilling into end grain of denser woods for dowels and such.
-- John, BC, Canada
View distrbd's profile
distrbd
2252 posts in 2564 days
#2 posted 03-20-2013 09:02 PM
I often use my regular titanium drill bits for wood and metal,as long as they are sharp and don’t walk when starting a hole,they do the job for me.
-- Ken from Ontario, Canada
nwbusa
#3 posted 03-20-2013 09:04 PM
Regular twist bits can do fine, as long as they don’t wander (which they tend to do without a pilot punch). The nice thing about brad points is that the center point helps to prevent the wandering in the first place. Also, the side spurs score the outer hole rim for a cleaner cut.
-- John, BC, Canada
View Syd Sellers's profile
Syd Sellers
30 posts in 2042 days
#4 posted 03-20-2013 09:11 PM
I like the ones at Woodcraft. Nice German made sets are available…http://www.woodcraft.com/search2/search.aspx?query=Brad%20point%20drills
-- Syd Sellers Old woodturners never die, they just keep chipping away! http://www.rocky-roost-woodturnings.com
View MonteCristo's profile
MonteCristo
2099 posts in 2306 days
#5 posted 03-20-2013 11:08 PM
Twist drills will never cut as clean a hole as a brad point or forstner when drilling cross-grain. Twist bits do well in end grain but even there parabolic tip bits are better. Twist bits are readily available and easy to sharpen so many use them but they are really for metal workers.
View johnvoorhees's profile
johnvoorhees
7 posts in 2011 days
#6 posted 03-20-2013 11:19 PM
I purchased a set at Harbor Freight some years ago and have bever been happier.The main thing is to keep them sharp. You will never go back to ordinary twist drills for woodwork.
View woodman88's profile
woodman88
144 posts in 2766 days
#7 posted 03-20-2013 11:25 PM
I like the ones from WOODCRAFT stay away from the HF ones I thought I would give them a try and after using once they were dull
Peteyb
#8 posted 03-21-2013 01:54 AM
I like the boxed set of 28 from Lee Valley as it gives me a lot more options with bits and I won’t have to turn around and buy all the individual ones. I am hesitant of the WOODCRAFT the woodriver brand has some bad customer reviews and the german made have no customer reviews and don’t come in big set.
What does everyone think about this?
View gfadvm's profile
gfadvm
14940 posts in 2807 days
#9 posted 03-21-2013 02:02 AM
My Porter Cable set from Lowes has worked better than I expected and has stayed sharp!
5069 posts in 2610 days
#10 posted 03-21-2013 11:47 AM
I bought the Lee Valley set, and am really impressed with how good they are. You can’t go wrong with them.
Peteyb
#11 posted 03-21-2013 05:54 PM
Fred I think you really helped me making my mind up. I think that I am going to go with the Lee Valley set. I was told that when I started looking for a drill press to make sure that you get a nice set of brad point drill bits. It will make the drill press work even better. Thanks again everyone for all the comments.
View Ripthorn's profile
Ripthorn
1458 posts in 3102 days
#12 posted 03-21-2013 05:57 PM
I have a HF set that has worked quite well, but if I had my wish, I’d have the good Lee Valley ones, I just can’t spend that much to replace something I’ve already got right now.
View James Austin's profile
James Austin
27 posts in 3298 days
#13 posted 03-21-2013 06:15 PM
I bought a set of 8 or 16 I believe from Sears.
At least for me, I have never needed a wood working bit any more precise than 1/16th increments.
Mine are HSS.
You should also get yourself a set of regular twist drills through 1/2 inch, and a set of Forstner bits.
I’m happy with the quality I get at Sears.
-- Some people have a shop so they can build things, the rest of us build things so we can have a shop...
View ChrisK's profile
ChrisK
1984 posts in 3199 days
#14 posted 03-21-2013 06:50 PM
I have a set from Peachtree Woodworking, works great. Even better I bought on a half price sale.
www.ptreeusa.com
-- Chris K
View MrRon's profile
MrRon
4987 posts in 3361 days
#15 posted 03-21-2013 08:41 PM
Standard fractional drill bit sets contain 29 drill bits, ranging from 1/16” to 1/2” in 1/64” increments I think most woodworkers only use a few sizes. I have many drill sets over the years where most of the drill bits have never been used. There are only a few sizes that I use regularily, so now I buy high quality bits in only the sizes I use most often. That saves a lot of money. I would buy an inexpensive set and after a time, you will discover the sizes you use the most. I would then replace those with good quality ones. A 1/2” bit is commonly used, but a 31/64” or 15/32”?
