Good deal on walnut tree?
Forum topic by Marcus posted 03-20-2013 04:41 PM 1796 views 0 times favorited 11 replies Add to Favorites Watch
View Marcus's profile
Marcus
1163 posts in 2047 days
03-20-2013 04:41 PM
http://minneapolis.craigslist.org/hnp/mat/3684887938.html
Just saw this on craigslist. Anyone have an idea what a sawyer would charge to cut up a treat like this?
11 replies so far
View treaterryan's profile
treaterryan
109 posts in 2315 days
#1 posted 03-20-2013 04:45 PM
Boy, with that small of a diameter, I think you would be hard pressed to get a lot of heartwood out of each of these trees.
-- Ryan - Bethel Park, PA
View Tennessee's profile
Tennessee
2873 posts in 2542 days
#2 posted 03-20-2013 04:49 PM
I am assuming you would probably cut them down to 10’ lengths or less? That would make about 6 logs, 13-16” diameter. Around here in SE Tennessee, if you took the wood to the saw, you might get off for about $175-200 as a load. And it would be green, so you have to rick it for a while. That would be just straight flat cuts, no quartersawing, assuming 5/4.
If the guy had a portable and this seller allowed you to set up in their area, it probably would double at least, for the travel time, setup and teardown time.
treaterryan
#3 posted 03-20-2013 04:53 PM
You can see what I mean here. The white sapwood is essentially waste, and generally not used for woodworking.
View Kreegan's profile
Kreegan
1452 posts in 2174 days
#4 posted 03-20-2013 04:55 PM
Give these guys a call. Kyle Lindy is their sawyer and I’ve always had good dealings with him. They’re down near Lakeville.
http://www.morningwoodhardwoods.com/services--products.html
Marcus
#5 posted 03-20-2013 05:01 PM
Thanks Rich. I was at this website a while ago and forgot to bookmark it.
Marcus
#6 posted 03-20-2013 05:01 PM
And Ryan, thanks for the picture…you’re right, not much heartwood at all in that size. May not be worth the time/effort.
Kreegan
#7 posted 03-20-2013 05:04 PM
Are you a turner? You could get some decent turning blanks out of those. If you have a chainsaw, no need to get anyone else to cut it up for you. I already have a ton of walnut, or I’d be interested.
treaterryan
#8 posted 03-20-2013 05:05 PM
That might be an exaggeration of the sapwood, but you get the idea. Smaller Walnuts seem to have a higher percentage of sapwood versus the old ones.
Marcus
#9 posted 03-20-2013 05:12 PM
Rich -
Nope, not a turner. I emailed Kyle to see what they think.
View ironman246's profile
ironman246
6 posts in 2002 days
#10 posted 03-20-2013 08:04 PM
I have read that residential type walnut trees do not make for much good lumber.my 2 cents. Thanks
Ray
-- Waco, Texas
View WDHLT15's profile
WDHLT15
1748 posts in 2503 days
#11 posted 03-20-2013 11:57 PM
They are pretty small, will be sappy, and there is a 100% chance that they have metal in them coming from a yard. The lumber is probably not worth what you would have to pay the sawyer for destroyed blades. Most custom sawyers charge about $30 for every blade that hits metal. I sawed a yard walnut for a guy and hit nails and bullets. Trashed two blades.
