Jointer mounted Mortiser - Usefull?
« back to Joinery forum
Forum topic by Ziffster posted 03-20-2013 01:48 PM 1692 views 0 times favorited 7 replies Add to Favorites Watch
View Ziffster's profile
Ziffster
27 posts in 1798 days
03-20-2013 01:48 PM
I will shortly be upgrading my Jointer shortly and wondering what experience others have had with Jointer mounted mortisers like the one pictured below:
Are they any use – or are standalone bench top devices just as good (which often cost half as much as these accessories)?
I don’t do a whole lot of MT joints right since currently such a hassle (right now when I do make an MT joint I use my router to cut mortise & sliding bed table saw to cut tenon) instead taking the easy of either using a Kregg Joint or doing a biscuit joint.
7 replies so far
View grfrazee's profile
grfrazee
388 posts in 2042 days
#1 posted 03-20-2013 01:55 PM
Seems like it would get in the way when walking boards down the bed.
-- -=Pride is not a sin=-
View lab7654's profile
lab7654
266 posts in 2150 days
#2 posted 03-20-2013 02:00 PM
+1 with the above, unless that table collapses or takes down, it would definitely hang up on something.
-- Tristin King -- When in doubt, sand it.
View JesseTutt's profile
JesseTutt
853 posts in 2013 days
#3 posted 03-20-2013 02:02 PM
+2 with above. I like to be able to walk a long board through the jointer and the mortise attachment would be in the way. For M&T work I have a router mounted horizontally in a table that I use to cut the mortise.
View Bill White's profile
Bill White
4853 posts in 3863 days
#4 posted 03-20-2013 02:40 PM
I have never been a fan of multi-function machinery.
Bill
-- bill@magraphics.us
Ziffster
#5 posted 03-20-2013 02:48 PM
Yes the unit comes off easily, but the European machines seem to take a better approach by mounting the Mortiser on the backside so it’s out of the way (unless you want to locate the unit against a wall).
View Lee Barker's profile
Lee Barker
2170 posts in 2753 days
#6 posted 03-20-2013 04:11 PM
This seems like a reasonable way to increase the work output of the motor.
Each job usually requires resetting everything on a mortiser, so nothing would be lost in removing it and placing it on the back (or on a shelf) when it’s not in use.
I have the Laguna mortiser on a shopbuilt base and the footprint is a nuisance.
That said, I’d much rather mortise with the Laguna than with my Jet benchtop. The former is a sweet running finesse machine that does a great job and the latter is a bit on the crude in the hand-me-some-more- biceps sort of way.
Kindly,
View Loren's profile
9935 posts in 3551 days
#7 posted 03-20-2013 04:29 PM
I had a Robland J/P with a mortiser on the side. The mortiser
was robust, accurate and fun to use. Setting it up was
quick too.
