How many sheets of ply?
Forum topic by Bradford posted 03-20-2013 01:37 PM 2262 views 0 times favorited 18 replies Add to Favorites Watch
View Bradford's profile
Bradford
1434 posts in 4058 days
03-20-2013 01:37 PM
Topic tags/keywords: plywood question tablesaw
I’m building a cubby for my daughter and wanted to calculate how many sheets of ply I would need.
All I found online were dimensional calculators, but they are more for board length.
If anyone knows of a web link that helps, I’d really appreciate it.
Bradford
18”x36”x36” overall
center shelf 34 1/2”
four dividers at 18”
I don’t want to waste wood nor buy too much. I think (5) 48” Square sheets is correct, but I’d like a second opinion, kind of like “measure twice, cut once”. Thanks LJ’s
-- so much wood, so little time. Bradford. Wood-a-holics unanimous president
18 replies so far
16281 posts in 4454 days
#1 posted 03-20-2013 01:59 PM
If I’m understanding correctly, you could definitely get that out of no more than 3 half-sheets + 1 quarter-sheet.
Two half-sheets would cover the four sides, right?
One piece would suffice for the four dividers.
A quarter-sheet would give you the center shelf.
Am I missing anything?
View Marcus's profile
Marcus
1165 posts in 2255 days
#2 posted 03-20-2013 03:20 PM
Bradford -
Any chance you have a quick sketch of what you’re after. I’m with Charlie, its a bit hard to visualize with the info given.
View MT_Stringer's profile
MT_Stringer
3183 posts in 3467 days
#3 posted 03-20-2013 03:59 PM
I think you could possibly get more bang for your buck if you bought a 4×8 sheet of plywood and ripped it into 15 1/2 inch widths.
One strip would make the 36 inch sides with enough left over for a divider.
Cut and rip the others for your center shelf and the dividers.
Efficient use of the wood would work as long as you keep your rips less than 16 inches. That allows for the thickness of your blade and to trim off the rough outer edge of the plywood.
Dado the backs and add a 1/4 inch piece of Birch plywood and it should be nice and sturdy and last a long time.
Here is one of my projects that is similar to what you are talking about.
Hope this helps.
Mike
#4 posted 03-20-2013 04:08 PM
Mike brings up a good point.
I thought about suggesting whole sheets, but I assumed the transportation and/or handling was a problem you were trying to avoid. Still, regardless of what size pieces you are willing to work with, the best way to maximize your cost efficiency is to tailor your project dimensions to your material size rather than the other way around.
MT_Stringer
#5 posted 03-20-2013 04:56 PM
@OP – if you are buying your lumber at one of the big box stores, they will cut it for you. Just ask them. I have seen a sign where it stated a max of 2 cuts free.
So…you cold get them to cut a full sheet into three pieces – 2 @ two 36 inches. Then you could haul it easier and rip it easier also.
Just thinking out loud today. Hope this helps.
View pintodeluxe's profile
pintodeluxe
5816 posts in 3049 days
#6 posted 03-20-2013 05:11 PM
One more sheet that you figure. Always one more sheet.
#7 posted 03-20-2013 05:42 PM
@Mike: One time, before I owned a truck, I made the mistake of letting the box store cut a sheet of plywood for me. The blade on their panel saw was so bad that I lost an inch of material on either side of the cuts to splintering. Luckily, I had material to spare, and was only letting them cut it so I could transport it easily.
117417 posts in 3813 days
#8 posted 03-20-2013 06:02 PM
This might help
http://maxcut.soft32.com/
View waho6o9's profile
waho6o9
8539 posts in 2812 days
#9 posted 03-20-2013 06:10 PM
Maybe sketch a drawing of what you want and that of a sheet of plywood.
Mark out your partitions, shelves, etc. Take into account the blade thickness,
and joinery, etc.
If the lumber store is close by I’d start off with 2 sheets. Lowes has partial sheets of
plywood available as well. This could make your 4 – 18 inch dividers.
HTH
View AandCstyle's profile
AandCstyle
3184 posts in 2493 days
#10 posted 03-21-2013 01:59 AM
I agree with Jim, use maxcut. It is free for 30 days of use IIRC.
-- Art
MT_Stringer
#11 posted 03-21-2013 02:14 AM
”@Mike: One time, before I owned a truck, I made the mistake of letting the box store cut a sheet of plywood for me. The blade on their panel saw was so bad that I lost an inch of material on either side of the cuts to splintering. Luckily, I had material to spare, and was only letting them cut it so I could transport it easily.”
OUCH!
Bradford
#12 posted 03-21-2013 10:26 AM
Thanks to all who responded. I only have a car for transport of cut panels. I looked at MT Stringer’s project, mine is double the size if you stack two of his. I going to that MAXCUT link to check it out. Thanks A1Jim. And PintoDeluxe, yes I always buy more wood than need, that’s why I have a piece of every board that I ever bought,(leftovers). I will include a picture of my draw up in a little while….....A lot of excellent info.
If I can be patient and wait, the correct info always comes from LJ’s. It drives my nuts searching the net for specific info. So again THANKS to all. You are truly my friends.
Bradford
#13 posted 03-21-2013 01:30 PM
Kreg Pockect Hole System
I included a draw up of the “BAG CUBBY” I hope it imported correctly. Cheers!
View CrazeeTxn's profile
CrazeeTxn
151 posts in 2186 days
#14 posted 03-21-2013 04:04 PM
Bradford -
Check out http://cutlistplus.com/features.aspx They have a free version (no trial) that will let you put up to 5 parts. I used it for a while then upgraded to the $90 version once I figured it out. Once you have your lumber dimensions loaded, you put in your parts and it shows you a diagram of cuts and how to make them. Lets you add for waste, kerf, etc.
Pretty neat little program.
View canadianchips's profile
canadianchips
2616 posts in 3233 days
#15 posted 03-21-2013 05:21 PM
Design questions:
Wondering Why you want 18” depth….....16” depth will maximize a sheet of plywood.
Next question 36” x 36”.......Wood a cabinet 32” x 32” work…....once again maximizing a 4×8 sheet better.
32+32+32 = 96
16+16+16 = 48
If you can readjust measurements a little you will utilize 1 sheet much better !
“Just my opinion”
