Ha...who needs CNC?
« back to Woodturning forum
Forum topic by REO posted 03-20-2013 04:24 AM 2151 views 0 times favorited 8 replies Add to Favorites Watch
View REO's profile
REO
928 posts in 2069 days
03-20-2013 04:24 AM
I did some playing around today on the DIY lathe. It was all about what was required to do a particular operation and get it done quickly. In all it took about 6 hours. Just bare not even scuffed for finish. You can’t do this on a router crafter, Legacy or a Laguna but You can do it on your lathe at home! Takes some time and some thinking.
I took about an hour to cut the template and turn the basic shape.
Took an hour to get the tooling change and get the offset on the router and template. Then I cut the first two sets of grooves. The rod rides against a pillar to keep the cutter 90 deg to the surface.
I needed a small diameter so I used a piece of pipe on the tail stock center for tracking the cable. I drilled a hole through the pipe so the cable would bite and not slip. I disconnected the longitudinal feed wheel so the longitudinal feed would move with the least amount of effort and turned the work this advanced the longitudinal feed at a set rate like threading on a metal lathe. I had both of the cables running side by side so when I wanted to change the direction of the spiral I just hooked up on the other cable. ! hour there
For these it was back to hand cranking.
Everything in the bag of tricks for today! Swivel router mount. Perpendicularity post. Template and follower.
The unfinished finished product!
About 10 inches in diameter and 12 inches tall
8 replies so far
View Mosquito's profile
Mosquito
9304 posts in 2288 days
#1 posted 03-20-2013 04:27 AM
That’s pretty cool, nice work :-)
-- Mos - Twin Cities, MN - http://www.youtube.com/MosquitoMods - http://www.TheModsquito.com
View Woodknack's profile
Woodknack
11608 posts in 2375 days
#2 posted 03-20-2013 05:06 AM
Wow. Impressed.
View Wildwood's profile
Wildwood
2305 posts in 2130 days
#3 posted 03-20-2013 11:04 AM
Check out video, and his library you can do it too!
http://www.jeffsturnedwood.com/Video.html
http://www.jeffsturnedwood.com/GalleryMenu.html
Can you make another exact copy of the first? Just kidding looks good! I was impressed with the initial form without embellishments.
-- Bill
View Jack Gaskins's profile
Jack Gaskins
46 posts in 3009 days
#4 posted 03-20-2013 11:19 AM
Outstanding. I love it. Wished I had one of those. How much does it cost to make a lathe anyway? I would like to make a 12-16 inch swing lathe with a short bed so I can stand on the end use tools rather than leaning over the bed. Something like those homemade bowl lathes you see around the internet.
-- USAF Ret. 2006
View jap's profile
jap
1251 posts in 2049 days
#5 posted 03-20-2013 12:17 PM
wow!
-- Joel
View helluvawreck's profile
helluvawreck
31044 posts in 2862 days
#6 posted 03-20-2013 01:18 PM
Nice work; nice machine.
helluvawreck aka Charles
View REO's profile
REO
#7 posted 03-20-2013 05:09 PM
Bill I can make an exact duplicate! In either rotation! The headstock and the longitudinal feeds are locked together. I used a cable on the proof of concept but the final install calls for chain on the indexing ring you can see in the back of the lathe spindle and 1/4 inch cable running the length of the bed in a parallel loop. this way I can lock onto either for left or right hand leads. I had not see the Jeffsturned woods before, thanks for the link. it would appear that he does his more free hand and follows up with a lot of hand work. they are beautiful!
Jack I have about 400 in this one. I have had some parts for years. I had the motor, the large I beam and the steel for the legs laying around. I have had the linear slides and electrical parts with the exception of the VFD for several years. The tailstock is one of four I have for a 10” atlas lathe. I work as an industrial mechanic and if I think I can use it when it thrown away I ask to have it. the front 2” dia guide rail was 125 dollars by itself! the cost of steel has gone crazy!
Thanks for looking!,and for the comments! I have been needing a little kick in the pants for finishing this project off. once the weather gets good I have to finish off an addition on the house or I may have a stormy summer lol.
View ironman246's profile
ironman246
6 posts in 1970 days
#8 posted 03-20-2013 08:09 PM
That is a very nice peice. Looks like you got it going on.
Ray
-- Waco, Texas
