| Forum topic by BJODay | posted 64 days ago | 457 views | 0 times favorited | 8 replies | ![]() |
64 days ago |
Topic tags/keywords: flatten joints Hi, In the past I have made cabinets using frames w/plywood sides and backs. I am trying to make a small bookcase/CD cabinet and I am making the top and sides out of 3/4 red oak. I have to join two boards together. I am using a biscuit joiner to glue them together. I can see as I am gluing them up that I will need to work the joint to flatten it out. Not a lot but it will need some work. The pieces will be too wide to fit in my brother-in-laws planer. I have a palm sander but it is very slow. Is a random orbit sander a better tool for this task? I have a jack plane but I am not very good with it. Plus I’ve watched a few videos on planing and I have to tune up my cheap plane before trying anything difficult. Any advice is appreciated. Thanks |
8 replies so far
#1 posted 64 days ago |
The easiest way to flatten them is start with flat and square boards. flatten one face on a jointer. Then with that face on the fence, joint the edges. Run it through the planer with the flat face down and it will come out nice a flat. Take some time to learn to make them flat before gluing them up. It will help quite a bit. Already glued them up and they need to be flattened? Lay it in a manner that helps keep it stable, such as crown up. Plane across the grain to level it out. Use winding sticks to help flatten it end to end. use a straight edge (level or framing square) to help reveal the high spots. Mark the high spots and plane them down. You don’t need expensive tools to do this. I have a very nice, very flat cherry table that I made flat with a $12, small, Stanley block plane. A sharp blade and patience are key. Some people flatten panels with nothing more than a card scraper. |
#2 posted 64 days ago |
Sounds like the boards are already glued up and BBrown626 has given some good advise. I have a few old planes as well as some LN new ones. I like you did not know how to tune a plane, but I found that if you learn to sharpen the blade so it will shave hair off your arm it work good enough to flatten your boards. Once you can get 2-3 thousands shavings you will be on your way. It should not take to much planing if your as close to flat as you indicate. Planing across the grain is important to quickly get them even,then smooth them with the grain.You will find that working with a sharp plane is a joy. |
#3 posted 64 days ago |
for me? #5, #7, #5 1/2. If that’s not an option, then what BBrown626 is describing seems like it should work rather well. -- Mos - Twin Cities, MN -- Stanley #45 Evangelist - www.youtube.com/MosquitoMods |
#4 posted 64 days ago |
I use bench planes. They are the right tool for You can make a tool called a sanding board, which |
#5 posted 64 days ago |
Could you do something like project below? |
#6 posted 64 days ago |
Hotbyte, That jig looks pretty cool. I may not have been clear on the original post. The boards are fairly flat, I need to dress up the joint where the boards meet. I think I was a little sloppy when I cut the biscuit slots. There is a slight lip in the center of the joint, maybe 1/32” high on one side. The ends of the joint lined up flush and will only need light sanding. I learn something on every project. |
#7 posted 62 days ago |
Thank you everyone for the info. I used a scrapper for the first time and I was surprised by the amount of material I could remove. I am dressing up my planes and when they are cleaned up I’ll try them out. I’m hoping to smooth the boards to within sanding tolerances. Thanks again |
#8 posted 62 days ago |
I would use my stroke sander but don’t mind me I’m just blowing my horn because I have one. :-) -- A tube of calk and a gallon of paint will make a carpenter what he ain't |
| Forum | Topics |
Woodworking Skill Share
8794 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
81 |
Finishing
1534 |
3551 |
15789 |
Hand Tools
2037 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6162 |
