bandsaw table question
Forum topic by amite posted 03-19-2013 10:29 AM 827 views 0 times favorited 4 replies Add to Favorites Watch
View amite's profile
amite
16 posts in 2449 days
03-19-2013 10:29 AM
My 14-inch Delta’s table is about 1/16” higher on the feed side than on the exit side. Is this normal? The saw sustained damage, and I want to know if it affected the table. If this is a problem, can it be bent back into shape, or is it brittle?
-- "That's not a gap, it's an expansion joint!"
amite
#1 posted 03-19-2013 12:25 PM
Update: inserted nail set into hole at end of table slot, which helped. The halves of the table still aren’t perfectly coplanar (used to teach geometry), but I can now slide wood back and forth as needed.
View mski's profile
mski
439 posts in 4219 days
#2 posted 03-19-2013 12:32 PM
Cast iron IS brittle. is the table flat ? if so shim like you posted above.
-- MARK IN BOB, So. CAL
View toolie's profile
toolie
2148 posts in 2867 days
#3 posted 03-19-2013 05:50 PM
sounds like you’re missing the table alignment pin.
amite
#4 posted 03-19-2013 06:09 PM
@toolie: yes, I am, but that nail set is a perfect fit. That pin is $5.52 from ToolPartsDirect, but probably with $11.99 shipping!
