Upright Piano
Forum topic by Mike posted 66 days ago 131 views 0 times favorited 3 replies Add to Favorites
View Mike's profile
Mike
65 posts in 154 days
66 days ago
Topic tags/keywords: question
Have an old Royal Upright Piano, it cannot be tuned and repairs are way too much. I do not even play piano. As for antique value the bench is worth more. It is in good shape I am keeping the bench.
Some of the trim boards are vaneered, the main parts of the case appear to be solid, stained pieces.
I know the wires are under a lot of tension, it has 2 nice looking legs in the front.
I thought about a sideboard, or an old Victorian Secretary.
I am wondering how hard it will be to take apart? How much deconstruction I can do without detruction.
Anyone know of any plans? Or any ideas may be helpful.
The Piano came with the house, nothing but a catch-all so if it has become a sort of shelf I want to make it more properly used.
-- Measure once cut twice....oh wait....ooops.
View Randolph Torres's profile
Randolph Torres
105 posts in 65 days
64 days ago
While researching one day I ran across a beautiful bar made from a piano. They guted it and placed shelves and mirror in back inside took the legs off and hung it on the wall with a small pedistal to bear the load made from the legs. It might have been an old issue of Fine Woodworking. If I run across the article again we will get you some images and the article. Randolph@cooperedpatterns
-- another tip from cooperedpatterns
View John Gray's profile
John Gray
882 posts in 422 days
64 days ago
Sounds like Randolph Torres has a good idea.
View brianinpa's profile
brianinpa
941 posts in 259 days
63 days ago
My son plays the piano, and I had an old player model that was in the same shape as your piano. I took it apart one piece at a time and turned the keys into a keyboard shelf that he can put his “stuff” on above his playing piano. I turned the top into an antique looking shelf to hold my wife’s antiques.
I didn’t need anything big like a sideboard, so I just built what I wanted/needed with the lumber I had. What I did discover is that pianos a built! Rather than messing around with the strings, I just used a big bolt cutter to loosen the strings.
Bookmark And Share This Page
