Stanley #4 plane blade help
Forum topic by Shopsmithtom posted 2179 days ago 2692 views 0 times favorited 6 replies Add to Favorites Watch
View Shopsmithtom's profile
Shopsmithtom
768 posts in 2360 days
2179 days ago
Topic tags/keywords: sharpening planes blades honing planing
For some reason, I’ve decided to put a new edge on a Stanley #4 plane blade that a previous owner ground to an angle that’s obviously incorrect. (why I decided to play with this plane in the first place is a story for another time) The problem is, I don’t know what the correct blade bevel angle is. Heck, I don’t even know if that’s what it’s called. Anyway, I’m betting that somewhere in this group, someone (or lots of folks) know what the correct angle is….so, help! -SST
-- Accuracy is not in your power tool, it's in you
View WayneC's profile
WayneC
9596 posts in 2262 days
#1 posted 2179 days ago
25 degrees. Also you need the back flattened and polished. Here is a link to on-line sharpening instructions.
http://www.hocktools.com/sharpen.htm
View mot's profile
mot
4912 posts in 2202 days
#2 posted 2179 days ago
Well, correct blade bevel angle is a bit of a tough one with a #4. In a bench plane like this the bevel is down so the bevel angle has no bearing on the cutting angle. The iron angle is 45 degrees with that plane. So, I tend to use a 30 degree bevel with about a 3-5 degree microbevel to make honing easier and faster. The cool thing about a 45 degree blade angle is that you can incorporate back bevels into the iron to gain steeper cuts for different planing situations. As I don’t particularly have a great understanding of those situations, I go with the 30 degree primary with a microbevel as stated for honing ease. I believe that, based on what I’ve read, that 10 degree of relief is pretty much a general purpose angle. Now, my answer is based on things I’ve read and I make no claims to be a hand plan officianado. I use them with delite, but with a healthy dose of awe and wonder. I sharpen everything with jigs in order to maintain the bevel that I’m familiar with.
I hope that helps a bit. I’d wait for Wayne to chime in here though!
WayneC
#3 posted 2179 days ago
LOL our posts passed on the wire. 25 is more of the factory grind. I agree with Mots post as well.
View USCJeff's profile
USCJeff
1041 posts in 2233 days
#4 posted 2175 days ago
Not exactly on topic, but I sharpened my three planes yesterday. I have a guide that secures the angle. Not sure what angle it is, however. Anyways, I have never even remotely gotten a shaving when using a plane. THe plane would mostly “chatter” and skip down the wood. Now that they are sharp, I got shavings without effort. The was very gratifying! I was in the shop about 4 hours after that and kept turning for a plane for this or that. So, setup is paramount!
Now if I could only get a good burr on my card scraper. I have seen how to sharpen these numerous times. Pretty simple, right? Not for me apparantly. I used a screwdriver as a burnisher. The card was squared prior to trying to get the burr. I hold the screwdriver at a 15degree angle and stroke the scraper that is in the vise. I think I should just buy a burnisher.
Plane Success
-- Jeff, South Carolina
Shopsmithtom
#5 posted 2174 days ago
Thanks for the help, guys. I messed around with mixed results without a jig, and before I grind the blades down to little nubbins, I’m going to set up a jig to get a proper result. I know they can be purchased, but what’s the fun in that? -Shopsmithtom
WayneC
#6 posted 2174 days ago
Lol – Enjoy the fun….
