weathered look
Forum topic by RH913 posted 03-18-2013 11:59 PM 3701 views 1 time favorited 18 replies Add to Favorites Watch
View RH913's profile
RH913
52 posts in 3219 days
03-18-2013 11:59 PM
Hi all
Looking for an easy way to make new pine look gray and weathered??
Or at least a way, easy or not??
-- RALPH
18 replies so far
View TCCcabinetmaker's profile
TCCcabinetmaker
932 posts in 2589 days
#1 posted 03-19-2013 02:17 AM
could try lye and water, then hydrogen peroxide, it takes a bit of time but it will grey it some.
-- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them.
View RussellAP's profile
RussellAP
3104 posts in 2521 days
#2 posted 03-19-2013 02:20 AM
If you want authenticity, bury them in some dirt wrapped in cloth for a year. I’ve actually done it so don’t laugh. I’d ask Charles Niel about it. He’s here on LJ’s.
View Lifesaver2000's profile
Lifesaver2000
556 posts in 3346 days
#3 posted 03-19-2013 02:32 AM
Here is a how-to over on Ana White’s site:
http://ana-white.com/2012/06/weathered-pine-stain
View Manitario's profile
Manitario
2702 posts in 3117 days
#4 posted 03-19-2013 05:39 AM
I think that I’ve seen this used in a home improvement mag before to get an “aged” look on pine. I haven’t used it myself though, so I can’t vouch for its success:
http://www.ecowoodtreatment.com/
RH913
#5 posted 03-19-2013 12:45 PM
Thanks for the quick responses.
-- RALPH
View Sandblastguy's profile
Sandblastguy
42 posts in 2345 days
#6 posted 03-19-2013 02:31 PM
I have attached a link to a product that I have used and it will make your pine look weathered. To make it even more weathered looking you could roughly wire brush it with the grain. hhttp://www.valhalco.com/index.php
-- Sandblastguy Orangeville On. Creating Art From Nature
View CharlesNeil's profile (online now)
CharlesNeil
2468 posts in 4105 days
#7 posted 03-19-2013 03:37 PM
yea , ask me, LOL
#1 take some steel wood , old bolts , nuts anything steel, ( no galvinized) put a couple of pads and the nuts and bolts in a glass jar and fill it with vinegar, leave it a couple of days, when ithe solution looks blackish its ready , it will add a darker grey color to the pine, be sure to experiment with the dilution, as it can make it pretty dark quick. If it isnt reacting then do the green tea solution below first.You can kick the reaction to be stronger and quicker by adding about a teaspoon full of muratic acid, to a quart ,but please use caution, I just let the vinegar do the work, much safer.
here is another alternative http://lumberjocks.com/topics/48028#reply-608933
#2 option, get some ferrous sulfate aka iron vitiamin supplement ( read for the higest content of ferrous sulfate), any drug store will have it ,( ask which has the higest content) dissolve 5 or 6 tablets in some water.Next brew you up some green tea, really strong, I use about 4 or 5 bags to a pint . apply the green tea this adds tannin to the pine, then when dry wipe with the ferrous sulfate solution and it will give you a grey. Experiment a little, with your concentrations and you can get what you want.
If you dont use the acid both are water soluable and quite safe .
A good wire brushing with the grain can add some texture, if you have yellow pine sand blasting works super well, it gives a super weathered look.
View Dwain's profile
Dwain
582 posts in 4093 days
#8 posted 03-19-2013 04:59 PM
I agree with the vinegar and steel wool mixture. Just tried it last week. It’s amazing how well it looks. I tried it on pine and cedar. Worked well on both.
-- When you earnestly believe you can compensate for a lack of skill by doubling your efforts, there is no end to what you CAN'T do
View Steve Peterson's profile
Steve Peterson
395 posts in 3316 days
#9 posted 03-20-2013 05:36 AM
Lots of good ideas above to make it look old and weathered.
Sandblasting can be used to give it a weathered texture.
-- Steve
RH913
#10 posted 03-20-2013 01:27 PM
Thanks again
I will try some of these and let you know how it works out.
-- RALPH
View IrreverentJack's profile
IrreverentJack
727 posts in 3077 days
#11 posted 03-20-2013 03:46 PM
You might be looking for a weathering/bleaching stain or oil. When I worked as a house painter years ago we called it Cape Cod stain. It would turn cedar shakes a nice even gray in a few weeks. It was popular on additions because it would match the original siding pretty quickly. This might be it. -Jack
View lumberjoe's profile
lumberjoe
2899 posts in 2482 days
#12 posted 03-20-2013 05:37 PM
View redSLED's profile
redSLED
790 posts in 2127 days
#13 posted 03-23-2013 04:05 AM
Propane torch burn the surface. File brush off all the char. Do a quick but random pressured pass over the wood with a grinder wheel (sawmill effect), then 100 grit scuff sand. Leave outside after rain and sun with some dirt rubbed in. Then a quick sandblast to the areas between the grain lines. Quick 120 grit scuff sand. Steel wool/vinegar stain for the finale. You could mix up the first 6 steps and see what works best.
View distrbd's profile
distrbd
2252 posts in 2680 days
#14 posted 05-23-2013 02:32 PM
I’m about to try the vinegar steel wool trick again,the last time it left a very light black color which could have easily been achieved with diluted Ebony stain in fraction of the time,but my mixture was not as dark as it should have been which is probably why the first experiment failed.
I’m anxious to try this new minwax #271(Classic Grey) ,although it looks fake Grey from the pics.
Here’s a link I found which shows all the techniques mentioned here plus a few pics to boot:
http://www.craftaholicsanonymous.net/how-to-age-wood-tutorial-guest-post-from-que-linda
-- Ken from Ontario, Canada
View bondogaposis's profile
bondogaposis
5148 posts in 2585 days
#15 posted 05-23-2013 06:36 PM
Thinned out gray milk paint works as well.
-- Bondo Gaposis
