Pitting on sliding bevel arm
« back to Hand Tools forum
Forum topic by Benvolio posted 03-18-2013 09:49 PM 827 views 0 times favorited 2 replies Add to Favorites Watch
View Benvolio's profile
Benvolio
148 posts in 1927 days
03-18-2013 09:49 PM
Hi there.
The handle of my bevel gauge restoration came out a treat but I can’t get past the pitting in the steel arm.
I’ve tried grinding away with my 250 water stone but this will thin the metal too much, ditto with 120 paper.
So I’m trying to polish out the surface with wire wool. The surface is lovely and smooth to the touch but marred by the potholes.
The picture is after a while of buffing with plumbers grade wire wool and wd40.
Would a rust removal solution take away the discolouration? If so I can protect with wax so it doesn’t come back.
Any tips??
Many Thanks.
-- Ben, England.
2 replies so far
View Don W's profile
Don W
18710 posts in 2563 days
#1 posted 03-19-2013 12:16 AM
Try a medium wire wheel, even a small one on a drill should get it.
View Tim's profile
Tim
3805 posts in 1957 days
#2 posted 03-19-2013 05:09 PM
The wire wheel will do it for sure, and you could try a brass wire wheel if you want to remove the least metal possible and reduce the chance of a brushed finish. Evapo-rust also does tend to take out the oxidation like that, even if it’s not red rust. I’m not sure about citric acid or the other methods. Personally I like to have old tools look old, but you have to make sure you get the rust out or you’ll have to do it all over again.
