Delta Planer parts
Forum topic by Dorado posted 66 days ago 325 views 0 times favorited 6 replies Add to Favorites Watch
View Dorado's profile
Dorado
5 posts in 69 days
66 days ago
I’ve been waiting since the early part of February for replacement parts for my Delta planer. I have found out through various forums that parts from Delta are back ordered due to a major screw up within the recent sale of the company.
I”m wondering if there are other resources that would be able to supply the parts in a timely manner , i.e. used, so that I can get back into the groove and finish milling.
Thanks and as always Work Safely!
Dorado
View JustJoe's profile (online now)
JustJoe
162 posts in 209 days
#1 posted 66 days ago
There are lots of company selling replacement parts online. What company are you waiting on it from now?
EDIT: And what part are you looking for?
827 posts in 664 days
#2 posted 66 days ago
If you google the Delta part number as in “Delta XXXXXX-XXXX”, you may find an aftermarket dealer that has it in stock.
-- I long for the days when Coke was a cola, and a joint was a bad place to be (Merle Haggard)
View Chris208's profile
Chris208
78 posts in 440 days
#3 posted 65 days ago
What parts are they? I went through the same hung recently with my Delta band saw. I found out that all the parts I needed were not proprietary to Delta and were available through either McMaster Carr, or locally.
If it’s hardware, and not an actual part, you can find it.
Chris
Dorado
5 posts in 69 days
#4 posted 65 days ago
The parts I need are a drive pulley, drive belt, the key to hold the pulley to the shaft and the cover that guards the pulley assembly.
I’ll try to google the parts and see what pops up. McMaster Carr is something I hadn’t thought of.
Thanks!
Dorado
View firemanbsa's profile
firemanbsa
6 posts in 1462 days
#5 posted 65 days ago
Check with a local industrial bearing supplier or with Granger the pulley will need to be sized for the shaft and the proper diameter to get the correct speed. The drive belt and key should be available at a good parts store or hardware store. On the cover I would check with a local heating and air company that makes duct work. They should be able to bend and rivit a cover you may need to add a little reinforcement with some light angle Iron avalable at most hardware stores or many big box stores.
-- parts is parts
View CTobes's profile
CTobes
1 post in 65 days
#6 posted 65 days ago
What model of Delta Planer are the parts for? I have a TP305 with a burned up motor and could make you a great deal on the parts you’re looking for.
CTobes
