Used table saw check list
Forum topic by dschlic1 posted 03-18-2013 01:55 PM 1852 views 0 times favorited 12 replies Add to Favorites Watch
View dschlic1's profile
dschlic1
442 posts in 2113 days
03-18-2013 01:55 PM
Topic tags/keywords: question tablesaw
In the next month or so I will probably be purchasing a used table saw. I would like to generate a check list of things to look for when actually inspecting a prospective saw. At this point I would like the list to be brand generic. I have thought of the following points:
1. Check for blade runout. Maybe arbor related.
2. Check blade alignment. Both vertically and in line with the miter slots
3. Check size of miter slots. Should be 3/4” wide by 3/8” deep.
4. Rotate the motor and/or arbor to check bearings
5. Check for play in arbor.
6. Run saw and check for excessive vibration or noise.
7. Check operation of fence. Clamps straight, moves easily, no play.
8. Check for accessories: miter gauge, blade guard, riving knife etc.
9. Check table flatness.
Can anyone add more items?
12 replies so far
View SamuraiSaw's profile
SamuraiSaw
515 posts in 2108 days
#1 posted 03-18-2013 01:59 PM
I would avoid right tilt saws. Left tilt saws have a number of advantages, including safety and accuracy.
-- Artisan Woodworks of Texas.... www.awwtx.com
View toolie's profile
toolie
2144 posts in 2772 days
#2 posted 03-18-2013 07:00 PM
while i agree that left tilt saws, with large rip capacities, aren’t subject to some of the potential kickback scenarios that right tilts can be subject to, the ‘72 unisaw i refurbished and sold was every bit as accurate, with it’s OEM jetlock fence, as the two emerson built 10” contractor saws i opted to keep in it’s place.
also, check out this new saw alignment article:
http://www.newwoodworker.com/basic/tsalign.html
many of th ealignment items should be checked as part of a used TS review.
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3302 days
#3 posted 03-18-2013 07:05 PM
I love my right tilt Unisaw. The fact that I can put a router extension table on the left wing (opposite the motor cover) is a nice plus, IMHO.
-- jay, www.allaboutastro.com
View nwbusa's profile
nwbusa
1021 posts in 2429 days
#4 posted 03-18-2013 07:08 PM
Not all saws come with a factory riving knife, but I personally would not own a TS that didn’t have a riving knife (unless it was a second saw that was set up only for dados). The stock miter gauge may or may not be worth using—oftentimes that is one of the first upgrades folks make to their saws. I’d want the blade guard only for when I went to re-sell the saw.
-- John, BC, Canada
View brtech's profile
brtech
1042 posts in 3066 days
#5 posted 03-18-2013 07:45 PM
Type of trunnions – contractor vs cabinet or hybrid.
Blade alignment or fence alignment can be off a little, and you can fix it. If you are rejecting saws because the blade or fence isn’t exactly square to the miter slot, you are being too picky. Could use it as an excuse to knock the price down if the seller doesn’t know that.
Don’t forget that a saw that hasn’t been used a lot, especially recently, can have a bad belt. Belts are cheap.
Mass is good. As much cast iron as possible. Cast iron wings are better than stamped steel, for example. But there are plenty of nice older saws that have stamped steel wings.
Many stock miter gauges are junk. If it’s missing, deduct a bit, but not a big deal. Guards on the other hand can get fairly expensive to replace, depending on model. I believe in guards, unlike nwbusa. You can take them off when they get in the way, but in lots of cuts, most guards are not in the way.
Understand what you can upgrade pretty cheaply. For example, you can put a Delta T2 fence on most contractor saws pretty easily. For the 113 Craftsman series, this is a common upgrade. About $150. That often makes a BIG difference.
View IrreverentJack's profile
IrreverentJack
727 posts in 2986 days
#6 posted 03-18-2013 08:03 PM
Avoid direct drive or motorized saws and those flexible shaft jobs.
Look for saws with upgrades and “extras”. Blades, featherboards, outfeed tables, router table extensions and the upgrades mentioned above add up fast if you buy them new.
Here are some views on left and/or right tilt saws. I have left tilt saws but IMO if your fence can be moved/set-up to the left of the blade they are equally safe and accurate. Left handed folks might like a right tilt better. -Jack
dschlic1
#7 posted 03-18-2013 08:24 PM
I agree that taking a dial indicator to check alignment is out of the questions. I am thinking of a rough check of alignment. If the saw is way out of alignment, then I would need to walk away. It appears that many of the later model table saws are not belt driven. I do however prefer to have a belt driven model.
Another item for me to add is that the table have square front and back. Many newer saws come with an angled front on the table for the fence. This prevents mounting an upgrade fence.
However I thank everyone for your comments
toolie
#8 posted 03-19-2013 01:18 AM
i don’t think i’ve ever seen a TS with a front table edge that isn’t both straight and perpendicular to the miter slots. can you point to an example of a saw with “an angled front on the table for the fence”?
IrreverentJack
#9 posted 03-19-2013 03:40 AM
Toolie, The Ridgid 4516 is one.
runswithscissors
2843 posts in 2168 days
#10 posted 03-19-2013 05:10 AM
A mobile base is a nice add on. You can make your own, but a factory built one will run you $90 or more.
View unbob's profile
unbob
810 posts in 2047 days
#11 posted 03-19-2013 06:05 AM
I bought a used contractors saw several years ago. It looked good, but it somehow had a badly warped table, not very noticeable just looking at it.
The right front corner was nearly 1/8” low. Also sunk in around the blade insert.
I just had a bad time with that saw trying to do anything on it, or getting it aligned.
From that experience. I take a straight edge with me when I am looking at used saws and other machines.
For reference, Powermatic spec was no more then .010” out on the the table for flatness, for the model 66.
dschlic1
#12 posted 03-19-2013 11:38 PM
Another example is:
Rockwell shop series
