When to replace the iron?
« back to Hand Tools forum
Forum topic by SamuraiSaw posted 03-17-2013 11:23 PM 1152 views 0 times favorited 23 replies Add to Favorites Watch
View SamuraiSaw's profile
SamuraiSaw
513 posts in 1871 days
03-17-2013 11:23 PM
I recently picked up a Stanley #4 from ebay. The plane was pretty rusty, but cleaned up fairly well. There was some pitting on the sole, but nothing I can’t live with.
The iron and chip breaker were in worse shape. The iron had been badly ground and wasn’t square. I got the cutting edge square and polished the back, but I’m wondering how well it will hold an edge with the pitting. At what point do you just buy another blade?
The blade is stamped 339, so I’ll definitely keep it for posterity!!!
-- Artisan Woodworks of Texas.... www.awwtx.com
23 replies so far
View paratrooper34's profile
paratrooper34
915 posts in 2859 days
#1 posted 03-17-2013 11:31 PM
SamuraiSaw, if you have pitting on the back that cannot be removed, throw it away, it is junk. If you can lap out the back to a point where it has no pitting and the thickness has not been compromised, you’re good. Once you grind a bevel on it, the pitting on the opposite side has no bearing on the cutting surface.
If you can, show some pics and we can help you out better by seeing where the pitting is.
-- Mike
View Don W's profile
Don W
18606 posts in 2474 days
#2 posted 03-17-2013 11:38 PM
Mike is right on. You can also use the ruler trick to gain some advantage.
View RussellAP's profile
RussellAP
3103 posts in 2193 days
#3 posted 03-17-2013 11:55 PM
A brief walk through an antique store will probably yield a few good irons, planes are rarely any good, but if it’s got a good blade, I’ll buy it for that. Look for the sweetheart, not easy to see.
SamuraiSaw
#4 posted 03-18-2013 12:10 AM
I tried taking some pictures and my camera won’t cooperate (I’m a carpenter, not a photographer!!). The pitting is pretty deep on the back, so I’m gonna call it toast. Is this a decent replacement?
I have another #4 coming that I believe is in better shape. I’m considering grinding this one into a scrub plane if the next one is in better shape.
SamuraiSaw
#5 posted 03-18-2013 12:21 AM
Finally got the camera to cooperate.
Don W
#6 posted 03-18-2013 12:25 AM
I’m not sure how much you’ve taken off already, but if its not much, I think its salvageable.
SamuraiSaw
#7 posted 03-18-2013 12:28 AM
The pitting at the top of the picture is fairly significant. Are you suggesting I continue to lap the back until I get through the pitting? Or are you saying to grind back towards the hole?
View ShaneA's profile
ShaneA
6889 posts in 2505 days
#8 posted 03-18-2013 12:33 AM
Hard to tell how deep they are. I would lap the back some more, nothing to lose but time. Doesn’t look too bad.
paratrooper34
#9 posted 03-18-2013 12:34 AM
I would try to lap it out, it looks like it is salvageable. Couldn’t hurt to try. At the least, you will get some practice and learn what will or will not be salvageable. Only thing it will cost is a little time. The pitting goes back far enough that grinding back is going to remove an awful lot of the blade, especially on the side on the top of the picture. Keep lapping it out and give it a shot, it may work out for you. I know I would try it.
-- Mike
Don W
#10 posted 03-18-2013 12:36 AM
Do you know how to do the ruler trick. It would work on that iron unless the pitting is worse than the picture looks.
Use a thicker ruler or another iron. Search on ruler trick and let use know if you need help.
Some use the ruler trick even without pitting. I will only use it if I have an iron like yours.
View Tim's profile
Tim
3734 posts in 1868 days
#11 posted 03-18-2013 12:44 AM
If you can’t lap it out, personally I’d buy a Hock, Lie Nielson, or Veritas blade before buying that new one from Stanley. You’ll get better, thicker steel from them, but I didn’t see the price on the Stanley. Otherwise like Russel said, you can get a good blade on a cheap vintage plane for less than the cost of a new blade.
Don W
#12 posted 03-18-2013 12:48 AM
+1 for what Tim wrote. I think yours is salvageable, but if not, get a decent one.
SamuraiSaw
#13 posted 03-18-2013 02:03 AM
Thanks guys. I’ll do a search for the ruler trick and let you know.
I’ll spend some more time lapping the back to see if I can get past the pitting.
View sikrap's profile
sikrap
1121 posts in 3266 days
#14 posted 03-18-2013 03:14 AM
If you’re not happy with it, PM me your info and I’ll send you an iron. It’ll need some work, but it won’t be pitted.
-- Dave, Colonie, NY
Don W
#15 posted 03-18-2013 11:39 AM
I’d take Dave up on his generous offer, then put a camber on the pitted blade. That minor pitting would be to bad for a jack plane. I have a 604 I use for a jack all the time.
