Table saw arbor nut; How tight is tight enough?
Forum topic by MrRon posted 03-17-2013 04:46 PM 3748 views 0 times favorited 14 replies Add to Favorites Watch
View MrRon's profile
MrRon
4764 posts in 3239 days
03-17-2013 04:46 PM
Topic tags/keywords: tablesaw
How do you determine when the nut is on tight enough? Everyone has different strength in their arms and hands, so it is difficult to know if the torque you are applying is adequate, correct or excessive.
14 replies so far
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 2068 days
#1 posted 03-17-2013 04:50 PM
I destroyed the arbor on my unisaw arbor by OVER tightening the nut. I was told by my machine rep/repairman that “sparkplug” tight was correct, hand tighten and then about 1/8 of a turn with the wrench, as the nut will tighten when the saw starts, and over tightening can be bad.
-- Who is John Galt?
View waho6o9's profile
waho6o9
8189 posts in 2572 days
#2 posted 03-17-2013 04:53 PM
Snug is adequate, and +1 for JoeyinSouthAustin.
View knotscott's profile
knotscott
8008 posts in 3371 days
#3 posted 03-17-2013 05:04 PM
Overtightening is bad, and can easily distort a saw blade. Arbor nuts are threaded so that they actually tighten when the saw spins, so they don’t need to be very tight. I go slightly more than finger tight….about what JoeyinSouthAustin described.
MrRon
#4 posted 03-17-2013 06:13 PM
Thanks all. I have been overtightening the nut for a long time now. Fortunately there’s no damage. The outside washer has some deformation on it from over-tightening.
waho6o9
#5 posted 03-17-2013 06:16 PM
Outside washer? Interesting, as my Bosch 4100 has no washer.
View MonteCristo's profile
MonteCristo
2099 posts in 2184 days
#6 posted 03-17-2013 06:35 PM
waho6o9 does it have an inside flange that will compress (a little) ? If not, doesn’t sound good to me. I have never seen a saw without a compressible washer before the nut.
View JamesT's profile
JamesT
102 posts in 1908 days
#7 posted 03-17-2013 07:08 PM
“Snug” is all that is needed. I’m getting ready to change an arbor shaft on a saw I just bought because of over tightening.
-- Jim from Doniphan
waho6o9
#8 posted 03-17-2013 07:13 PM
I’m not sure MonteCristo. I’ve just used it the way it was OEM
I’ll check next time for the inside flnage, and thank you for the
friendly advice.
View Bogeyguy's profile
Bogeyguy
548 posts in 2064 days
#9 posted 03-17-2013 07:25 PM
waho, googled the 4100 manual and the PDF shows an outer washer for the 4100-09.
-- Art, Pittsburgh.
joeyinsouthaustin
#10 posted 03-17-2013 08:05 PM
Waho Check page 30 here I have three of these saw and there is a washer between the nut and the blade, as bogey points out, I just am giving the link.
View bandit571's profile
bandit571
19972 posts in 2679 days
#11 posted 03-17-2013 08:13 PM
My old Craftsman #113 has a washer as well. Has a bit of a raised center to it, too. I guess to spread the torque a bit?
Tighten by hand, with the blade wrench resting on the openings edge. Finger tight, then just pull the blade towards me against the wrench. Plenty tight.
waho6o9
#12 posted 03-17-2013 09:08 PM
Thank you folks!
View Straightbowed's profile
Straightbowed
717 posts in 2294 days
#13 posted 03-17-2013 09:28 PM
JUST snug is good, snug and a bit is how I doit, I broke my wrench when I first got my 1023 on my first blade install learned my lesson them just snug
-- Stevo, work in tha city woodshop in the country
View Howie's profile
Howie
2656 posts in 2919 days
#14 posted 03-17-2013 09:50 PM
Snug. The blade turns into the thread so it won’t back out.
I suspect there are times when people can’t get their saw to cut straight that this may be the problem. JMHO
-- Life is good.
