| Forum topic by jumbojack | posted 67 days ago | 560 views | 0 times favorited | 6 replies | ![]() |
67 days ago |
I don’t know if this has been posted before, if so, it is worth another look. I WAS STUNNED! He certainly did not invent the lathe, but a 1000 years ago, he could have. -- Made in America, with American made tools....Shopsmith |
#1 posted 67 days ago |
Is that what you call a rule of thumb carpenter? -- A tube of calk and a gallon of paint will make a carpenter what he ain't |
#2 posted 67 days ago |
That was an enjoyable … and enlightening … watch with my Coffee Fix for the day! Comforting to see my style of carpentry in action too!! Thanks for bring this video to our attention jumbojack :) -- Elaine in Duncan |
#3 posted 67 days ago |
That’s about the crudest treadle style lathe I’ve ever seen, but it seems to work. It looks like he gets all his lumber from a dumpster (come to think of I could get better lumber from a dumpster). I’ve turned a few small flat rounds on a hand drill clamped to a bench an I thought that was crude. I suppose if you like this guy’s idea, you’d probably enjoy Roy Underhill’s DIY lathe he did years ago. One of the old Fine Woodworking books had a treadle plan or two as well. |
#4 posted 66 days ago |
It reminds me of some of the Rube Goldberg devices I’ve made in the past, including home made lathes. I wouldn’t want a lathe like that, but it was fun to watch. Here is one. Not a lathe, but a rounding jig for someone without a lathe. The square workpiece edges were first shaved off with a plane and then finish sanded in my little jig. -- Mike, American in Norway |
#5 posted 65 days ago |
You went one better than me, Mike, and put a tail stock on your drill lathe. I found that a bit of non-slip rubber under the drill helps, too, as well as a second clamp on the neck of the drill. The only thing I didn’t like about was you need an extra hand if you want to run the drill at a low speed. Actually, I think if I ever want to do much more on that scale I’ll just pick up the little lathe HB sells for close to $100 sometimes. |
#6 posted 65 days ago |
Now that was creative woodworking… I wish I had taken a picture of my creation a few years back. My ‘first’ lathe was my drill press – tipped it on its side and with a bearing stuck in the tables center hole had myself a workable adjustable variable speed lathe. |
| Forum | Topics |
Woodworking Skill Share
8794 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1534 |
3551 |
15789 |
Hand Tools
2036 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6161 |
