Help with Delta 34-670, please
Forum topic by Hugh1 posted 03-17-2013 02:28 AM 856 views 1 time favorited 3 replies Add to Favorites Watch
View Hugh1's profile
Hugh1
4 posts in 1866 days
03-17-2013 02:28 AM
Hey, I bought a used Delta 34-670 and can’t get it too cut 3/4 ply. From other posts on this forum, I suspect that it is the intenal belt in the motor. I tried to figure out how to get at the motor to pull the old part and inspect, but I can’t figure out how to get to it. Can someone give me a quick description of how one is to replace this part? Do I take the motor all the way out? Is there any secret to reaching all of the bolts? I felt like I was trying to squeeze myself into a metal box and then work like a contortionist to reach bolts that I couldn’t see.
Thanks.
Hugh
3 replies so far
runswithscissors
2724 posts in 1989 days
#1 posted 03-17-2013 06:42 AM
That model uses a cogged belt. I wonder if the “teeth” might be worn or broken off. Can’t help you with how to get at it though. You might be able to find a pdf of an owner’s manual or repair manual.
View pmayer's profile
pmayer
1026 posts in 3029 days
#2 posted 03-17-2013 10:44 AM
The belt replacement procedure is covered on page 21 here: http://www.mikestools.com/download/DeltaTableSawManuals/34-670.pdf
It’s not that difficult. The procedure shown requires flipping the saw but it can be done from underneath the saw as well if you don’t feel like flipping it.
View History's profile
History
399 posts in 1946 days
#3 posted 03-17-2013 11:55 AM
The Delta 34-670 was the first table saw that I bought new quite a few years ago. I had to change the coged belt on it once because I ran it on a really cold day and it stripped the cogs off the belt. At the time the belt was about $10, and if I remember correctly changing it wasn’t as bad as I thought it was going to be.
