Entry Doors Panel Question
Forum topic by GuitDave posted 03-17-2013 02:27 AM 1456 views 0 times favorited 8 replies Add to Favorites Watch
View GuitDave's profile
GuitDave
6 posts in 1847 days
03-17-2013 02:27 AM
Topic tags/keywords: entry carriage doors panels
Hi, so I’m new to woodworking and new to this forum. I’ve read posts for several years now just have never posted anything. So I have a question. I’m building some doors for my shop that are about 4ft x 7ft each made from African Mahogany. I’ve got the frames done (not glued together) and wondering how the tongue and groove panel is detailed. A company sent me their details and I guess I just don’t understand. I imagine the panels float in the bottom half of the door but what is this “continuous spline glued top and bottom” talk? What is that and what does it do? I’ve seen Norm do something like it when he built his doors but this is a little different. Can the panels not slide into the top just like it does on the sides? Maybe its for rain? Can someone explain to me whats going on? Thanks! Any tips would help – I’m sweating over the window muntins, too.
Here’s what Im sort of imitating:
Here’s the detail:
Here’s my frame (tongue & groove panels on bottom, windows on top):
8 replies so far
View pintodeluxe's profile
pintodeluxe
5568 posts in 2720 days
#1 posted 03-17-2013 03:01 AM
I have used foam weatherstripping on an exterior door, and it works well. The same concepts apply with doors as any floating panel, you need to let the panel move. I glue the panel top and bottom, but only at the center of the door. This lets expansion and contraction happen, but keeps the panel centered in the frame. You could glue one board centrally, and let the others float.
GuitDave
#2 posted 03-17-2013 03:50 PM
Hey thats a good idea, Willie and I will do that. But what about expansion in the up/down direction? As you can see in the detail, there is a 3/4”WD x 1/2”DP slot the panel sits in on the sides – but what happens at top/bottom? Do you recess the panels in the same manner or do they butt up against the rails attached by a spline? I see two problems with that: 1) it wouldn’t allow movement in that direction and 2) you would potentially see a gap if the two don’t butt perfectly. Im just having trouble picturing how that works. And I feel like if you just cut a slot in the bottom rail and recessed the panels in there, water would seep in. So maybe a spline at bottom rail and recessed in the middle rails…
Thanks for your comment
-Dave
View teejk's profile
teejk
1215 posts in 2591 days
#3 posted 03-17-2013 05:44 PM
I don’t think wood expands/contracts much lengthwise (proof is that your common 2×4 does not get appreciably longer/shorter. The continuous spline appears to be akin to a biscuit that keeps the panel in line with the top and bottom. My guess is there is no glue on the panel to frame. The foam is to stop rattling I think (some cabinet makers use something called “space balls”).
View GaryL's profile
GaryL
1099 posts in 2737 days
#4 posted 03-17-2013 05:55 PM
I assume they are showing glueing the spline into the rails. Then cutting a slot/dado into the top & bottom of the T&G paneling allowing the panels to move freely on the spline. Basically a long loose tenon, but only glued on one side.
Is your frame dry fitted or already glued?
-- Gary; Marysville, MI...Involve your children in your projects as much as possible, the return is priceless.
teejk
#5 posted 03-17-2013 07:41 PM
Gary…I think the design is to mount the panels into grooves in the stiles (no glue but a compressible material to allow for the side to side expansion/contraction). Tops and bottoms sounds like only the spline. Not so sure that is needed on the top but anybody in a freeze/thaw climate that has have ever had a wood garage door of stile/rail construction will be able to attest to the rot on the bottom rail. Caulk works for a while but sooner or later you are going to have a water pocket in the rail. With the spline you keep the rails solid and water should shed off. It all makes sense to me.
GaryL
#6 posted 03-18-2013 12:50 AM
teejk…we’re on the same line of thought. The top could be a spline or setting the panels into a groove.
”With the spline you keep the rails solid and water should shed off. It all makes sense to me.”
This is what I was thinking with the spline glued in with a waterproof glue it would shed the water out. Putting a chamfer on the rail would also help in keeping water out.
GuitDave
#7 posted 03-18-2013 03:22 AM
Thanks I really appreciate the advice. I understand now. I haven’t glued anything together yet. I think I am going to spline the bottom and recesses the top – and a chamfer at the bottom rail is a good idea, too. Thanks!
View MNgary's profile
MNgary
296 posts in 2324 days
#8 posted 03-18-2013 03:41 AM
I agree with GaryL
-- I dream of the world where a duck can cross the road and no one asks why.
