Older DELTA Rockwell Overhead pin router
Forum topic by liketosail posted 03-17-2013 01:43 AM 3354 views 0 times favorited 6 replies Add to Favorites Watch
View liketosail's profile
liketosail
31 posts in 1813 days
03-17-2013 01:43 AM
Does anyone have
one of these?
And do you like it and it’s best uses and weak points?
View rootertooter's profile
rootertooter
12 posts in 2811 days
#1 posted 03-17-2013 02:03 AM
i don’t any longer,but you have to make a lot of doors or trim to make it worth having It takes up a lot of shop space…
-- bob mt pleasant tn
View Grandpa's profile
Grandpa
3259 posts in 2547 days
#2 posted 03-17-2013 02:45 AM
Check with Loren
liketosail
#3 posted 03-17-2013 03:46 AM
This thing runs good on 110 v most I have found are 220v , not sure if it can be wired 220v.
No pin came with it so I will have to make one.
I plan to make some fluted boards for an archway with this..
I came across this today when I went to buy a older shaper and he offered me this pin router for $25.00 more
So I bought it and the shaper for $150.00 total.
one of my best deals yet on wood working tools.
View bigblockyeti's profile
bigblockyeti
4883 posts in 1593 days
#4 posted 12-09-2013 01:20 PM
A friend gave me one of these, I think a little newer than yours based on how the casting around the base looks. Mine is 230V and will need only a little wiring to get it up and running. It has two spindles, one on top and one below and the motor can be moved to either with the pin in the opposite. Even the machined surfaces still look good! Can’t wait to put it to work.
bigblockyeti
#5 posted 01-24-2016 04:35 AM
I finally got the pin router up and running, had to put more work than I thought into it, but it works great. The problem; I’m not using it anymore and it’s taking up space. I’m going to list it for sale for $350.00, if any Jocks are interested I’ll let you have it for $250.00. Should have pictures before too long.
bigblockyeti
#6 posted 01-24-2016 10:33 PM
Below is one picture of the pin router previously mentioned, more are available:
