Dust Hood for Delta portable planer
Forum topic by Kwit posted 03-16-2013 11:32 PM 6606 views 4 times favorited 5 replies Add to Favorites Watch
View Kwit's profile
Kwit
103 posts in 1983 days
03-16-2013 11:32 PM
Thanks to Lorin for his inspiration for a home built dust hood for his Delta planer
I know a lot of people own these – and they don’t sell a hood anymore
I took Lorin’s idea and put my own twist on it using a 12”x2.25” side register boot (purchased from Amazon)
You might be able to get one from your local HVAC supplier
The trick is to remove the blade guard and turn it upside-down. The register boot seems to be a perfect fit; I just used a piece of aluminum angle for a bottom cleat attachment and some sheet metal screws and Dow795 (structural adhesive sealant I get from work). I used a cutting wheel to grind the screw tips down after the adhesive set. I sealed the seams with black duct tape afterwards
Hopefully the pictures tell the tale – making one out of wood is a good option – I just went for a quicker, ready-made option
-- don't talk about it - be about it
5 replies so far
View Dallas's profile
Dallas
3599 posts in 2511 days
#1 posted 03-16-2013 11:36 PM
That looks good Kwit. I have a factory model on my 22-580 and it seems to leave a lot to be desired. I may have to use your idea and make one like it.
View Kwit's profile
Kwit
#2 posted 03-17-2013 12:31 AM
Keep in mind – I only used a side register boot to keep the hose to the side of the workpiece
You can use a standard 12×2.25 register boot with the opening in the middle – it may work better for you
I just felt this eliminated extra coupling or elbows that may have been cumbersome to the setup
View jeff's profile
jeff
1081 posts in 3489 days
#3 posted 03-17-2013 12:33 AM
I have to make one myself for my Delta and this is another option,thx for posting…
-- Jeff,Tucson,Az.
View History's profile
History
399 posts in 2006 days
#4 posted 03-17-2013 01:35 AM
I’ll bet that it works good. I’ve made a couple planer dust hoods from scratch because I have the machinery and the tools to do it, both similar to yours being side outlets, and they work great. Way to McGuyver it.
View CrazeeTxn's profile
CrazeeTxn
151 posts in 1975 days
#5 posted 03-17-2013 03:35 AM
Very nice. Gonna have to try this with my Craftsman. My shop vac does really good getting most of it, but I have a bigger d/c now and want to figure out ways to hook to 4” up to it.
