How do you cut your closet wardrobe tubes down to length?
Forum topic by noone posted 03-15-2013 03:53 AM 7045 views 0 times favorited 19 replies Add to Favorites Watch
View noone's profile
noone
583 posts in 2266 days
03-15-2013 03:53 AM
What kind of blade on your chop saw do you find works best to cut down these tubes to fit that leaves the cleanest cut?
19 replies so far
View MikesProjects's profile
MikesProjects
172 posts in 1896 days
#1 posted 03-15-2013 04:18 AM
If you’re talking about the 1 1/2” chrome plated ones I use a sawZall with a metal blade, the ends cover.
AH, but wait, your probably talking about wood. =) How about a blade with lots of teeth? Is what your doing paint grade or pre finished?
-- -Mike, Southern California, YouTube User ( Give & Take )
noone
#2 posted 03-15-2013 04:27 AM
Talking about an aluminum, nickel plated tube you get from Hafele.
http://www.hafele.com/us/external/catalog/CIB2012V2_html/CIB2012V2/ipad/ipad.html?21
Figured a chop saw would be the easiest and less jagged, but I don’t want to use my wood blade for it. And I don’t want to spend a fortune on a new blade either.
View waho6o9's profile
waho6o9
8187 posts in 2571 days
#3 posted 03-15-2013 04:35 AM
A cold saw. Hacksaw.
Or, a metal cut off blade on a little grinder.
runswithscissors
2750 posts in 2019 days
#4 posted 03-15-2013 07:04 AM
You can get little metal chop saws that use your angle grinder as the power. But you can free hand them quite cleanly if you are careful. Aluminum cuts fine with woodcutting blades, but I don’t know about the nickel plating. The only the mini chop saws I’ve tried was pretty wonky. A metal cutting (abrasive) blade can be put in a full size chop saw, but it seems like overkill for the job.
404 - Not Found
2544 posts in 2963 days
#5 posted 03-15-2013 09:13 AM
Metal cutting blade in a jigsaw works for me, clean up with a file.
View OggieOglethorpe's profile
OggieOglethorpe
1276 posts in 2104 days
#6 posted 03-15-2013 11:47 AM
+1 for the jigsaw and proper blade, then a light filing or 100 grit sanding block.
If you’re nervous, draw the cut line all the way around. Most of the cut surface will be hidden by the mounting hardware, so no need to sweat.
You could probably also use a tubing cutter:
noone
#7 posted 03-15-2013 11:49 AM
Thanks for all the ideas. I think I like the jigsaw option!
noone
#8 posted 03-15-2013 06:24 PM
Rick-
Are you saying that I could use my current 10” 60 tooth Freud Diablo blade on my miter saw to cut these without issue of damaging or dulling the blade? If so, that would be EXCELLENT!
View jusfine's profile
jusfine
2422 posts in 2920 days
#9 posted 03-15-2013 07:54 PM
Non ferrous metals can be cut with your Freud blade with no damage, but check on the composition of your tubes first…
-- Randy "You are judged as much by the questions you ask as the answers you give..."
woodbutcherbynight
4515 posts in 2403 days
#10 posted 03-15-2013 11:24 PM
Hacksaw, or if you have a recip saw a bi-metal blade works well. Small round file to clean the edges inside and out if you like. I would not use my chop saw no matter the blade, but that is just me.
View Handtooler's profile
Handtooler
1553 posts in 2126 days
#11 posted 03-15-2013 11:45 PM
How about a metal cutting grinder type blade 5/8” arbor 7” similar to the masonry blades but intended for metal either on your Chop/miter saw or on a circular saw? Would not this not also work? Just asking.
-- Russell Pitner Hixson, TN 37343 bassboy40@outlook.com
View Grandpa's profile
Grandpa
3259 posts in 2669 days
#12 posted 03-16-2013 01:42 AM
I believe you can get a blade for ferrous metal and a different blade for nonferrous metals. I would really be cautious about cutting this tube on a blade with teeth on it. People on here go crazy about needing splitters and riving knives but endorse this kind of thing. I would be really cautious. This thing will spin and be out of control before you have time to think about it.
noone
#13 posted 03-16-2013 01:47 AM
Grandpa
#14 posted 03-16-2013 01:53 AM
Thanks for the pics. That changes everything. Cut it with any saw that has a metal cutting blade or a good carbide blade. No problem.
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 2066 days
#15 posted 03-16-2013 02:43 AM
This tool has cut 1000 feet of chrome rods in the last 6 months at my shop, most faster tools leave heat marks, and this is easy peasy
-- Who is John Galt?
