| Forum topic by Rick M. | posted 70 days ago | 603 views | 0 times favorited | 18 replies | ![]() |
70 days ago |
Topic tags/keywords: jig sander diy shop made tool I’m considering adding some stationary sanders to my shop and I’m trying to prioritize between disc, belt, & drum. I used to build mostly furniture but these days I do a little of everything. There are 2 types of drum sanders – thicknessing (overhead) drum sanders and V (Velcro) drum sanders where the drum is in the table and you slide the wood over it. I’m leaning toward the overhead because it can be used for thicknessing. Any comments? Disc sanders – bigger seems better. If I build one, how big could I go practically with a 1.5hp motor? I’ll be building them so maybe I can combine 1 & 2. 1. disc sander [note: I know I can buy them but I want to build them] -- -- Rick M. |
18 replies so far
#1 posted 70 days ago |
Rick, I would think a drum sander capable of thicknessing would be a great thing to have, but I can’t speak from experience. I can tell you that my Delta belt/disc sander probably gets more use than any tool in my shop.
I’ve seen some great looking shop built drum sanders, and building your own makes a lot of sense because they are quite expensive. But it’s hard to justify building a disc sander, IMO, when they are relatively cheap. -- Charlie M. "Woodworking - patience = firewood" |
#2 posted 70 days ago |
I plan to build a combo of a drum and disc sander at some point. 12” is a pretty common disc sander size, and 1.5 HP should power both the drum and the disc without a problem. -- Brian T. - Exact science is not an exact science |
#3 posted 70 days ago |
Rick, With 1-1/2 HP a 12 inch disc should have no problems. What RPM is the motor? 3600 RPM may be too fast for 12”. 1750 or less would be good, too fast and you will burn the work. You will also have less vibration issues at slower speeds. Just looked at Grizzly’s site and they use 1-1/2 HP at 3450 rpm on a 15” disc. -- Chris K |
#4 posted 70 days ago |
Rigid oscillating sander, no contest. -- Bert |
#5 posted 70 days ago |
I’ve got an old old craftsman like Charlie posted. It gets used constantly. I built a drum sander (see my blogs) but to be honest I don’t use it as much as I thought I would. I’ve got a lot of flooring to do sometime in the future and it’ll get a work out then. I’ve also got the ryobi which just stays as a spindle sander. -- There is nothing like the sound of a well tuned hand plane. - http://timetestedtools.wordpress.com (timetestedtools at hotmail dot c0m) |
#6 posted 70 days ago |
Bert is this the one your are referring to? I am thinking about replacing my old Sears disc/belt sander with one of these! -- "I never met a board I didn't like!" |
#7 posted 70 days ago |
Yes, may be the best tool in my shop. -- Bert |
#8 posted 70 days ago |
Rick M. – here’s some ideas for building your own…I found them right here at LJ’s…imagine that….check ‘em out…I think they are some great ideas and builds !! http://lumberjocks.com/projects/43625 http://lumberjocks.com/projects/13699 http://lumberjocks.com/projects/37200 http://lumberjocks.com/projects/79331 -- Measure "at least" twice and cut once |
#9 posted 70 days ago |
CharlieM1958 I agree the most used in my shop as well. -- Live to tell the stories, they sound better that way. |
#10 posted 70 days ago |
I have an oss (Oscillating spindle sander), a 6×48 belt 9”disk. the Oss is a $100 throw away from menards, and the other is an older C-man. They both perform great. I did own a performax 22/44, and a performax 25×2. every open ended drum sander I have ever used had tip issues (sanded more on the left then the right ) if you didn’t take the tiniest cut at a very slow rate of speed. the 25×2 was a great two post machine that had dual drums. it would take 1/16” a pass without any troubles, a little pricey (new) and it took a 4×4 foot print out of my shop. I paid $225 for it and had $175 in putting it back together. in the end I didn’t have the room for it (and just wasn’t used enough)so it went for $900. on a side note the surface sanders make an obscene amount of powder fine dust, so make sure your DC can take it. |
#11 posted 70 days ago |
No offense to anyone here...but I think Rick M wants to build his own....not buy one -- Measure "at least" twice and cut once |
#12 posted 70 days ago |
Look at Bearpaws post, awhile back he made a V-Drum Sander with Accessories, I have been to his shop and it looks and works well. -- Live to tell the stories, they sound better that way. |
#13 posted 70 days ago |
I have a variety of sanders- Craftsman 6×48(took the disk off), 16/32 drum sander, Grizzly spindle sander, a couple of porter Cable belt sanders, and other small ones. I use them all. The 6×48 flattens figured wood that my jointer would tear up. I use a 36 grit planer belt. The drum sander saves a lot of time on cutting boards and boxes. They all make a lot of dust, but I need them all. Good luck building whatever you decide. I have enough trouble making wood behave, let alone metal! -- Robert, so much inspiration here, and so little time! |
#14 posted 70 days ago |
My 18/36 drum sander gets used on every project so build a drum sander first, then the combo belt/disc, then ya gotta have an OSS for curves! That ought to keep ya busy for a while! -- " I'll try to be nicer, if you'll try to be smarter" gfadvm |
#15 posted 70 days ago |
@ Bert, To build an oscillating system would be an interesting, but no impossible, challenge I’ve seen where people have built them and I even have a motor that goes up and down but it’s a little more complicated and it isn’t something I want to tackle just yet. @Charlie, But it’s hard to justify building a disc sander, IMO, when they are relatively cheap. Well smaller disc sanders are relatively cheap but I’m thinking big. Grizzly has a 15” that runs off 1.5hp but it’s $950 with freight. And that’s cheap compared to the Powermatic combo models. -- -- Rick M. |
| Forum | Topics |
Woodworking Skill Share
8794 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
81 |
Finishing
1534 |
3552 |
15795 |
Hand Tools
2038 |
Jigs & Fixtures
495 |
Wood & Lumber
2842 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6162 |
