what's wrong with some pitting?
Forum topic by HokieMojo posted 68 days ago 243 views 0 times favorited 12 replies Add to Favorites
View HokieMojo's profile
HokieMojo
414 posts in 265 days
68 days ago
I’ve seen some comments in the past that say to stay away from planes that have pitting. Why would this matter? As long as the entire surface isn’t uneven, wouldn’t the effect of those small pits be neglidgible? I’m trying to reconcile how huge grooves (corrugation) milled into the bottom of a bed are ok, but a dozen 1/4” pit marks can adversely affect performance.
I don’t doubt that pitting is bad, I’m just trying to understand why this affects performance but other irregularities in the bed don’t.
Thanks!
View Critterman's profile
Critterman
491 posts in 347 days
68 days ago
Jo, I’m not an expert, but my understanding is the pits collect sawdust/chips/gunk and can change your plane sole from flat to skewed. Now, the groves in some planes run length wise the full length of the plane so the chips/sawdust/gunk collect the go out the other end with out sacrificing the flat sole to wood integrity. To fix the problem some pits can be taken out of the bottom of a plane through refinishing and there are several articles floating around on how to do that (FWW, and I think someone did one here somewhere). Anyway, that’s my understanding hope it helps.
-- Jim Hallada, Chesterfield, VA
HokieMojo
68 days ago
That certainly makes sense. I guess I’d be less concerned with pitting on the sides of a plane body, than if the pitting was on the sole. Great explanation. Thanks for the insight.
View modestmouser's profile
modestmouser
15 posts in 84 days
68 days ago
Could you drop some epoxy or something into a pit and then smooth it out to repair it?
View Loren's profile
248 posts in 184 days
68 days ago
Pitting means poor condition to a collector. A deeply pitted plane
may be in danger or cracking or breaking but I don’t see how pitting
alone would affect a plane in use badly.
What matters is that the part that slides on the wood is smooth enough…
if the sole is grimed up with a lot of oxidation that’s no good.
I would avoid paying more than a few dollars for a bench plane that
had more than moderate surface rust though… and a badly pitted
iron is not worth the work to make it usable.
-- http://amherstcabinets.com - also a marketing consultant with expertise in direct response marketing for woodworking and online businesses - http://COPYMATCH.COM
View skeezics's profile
skeezics
100 posts in 256 days
68 days ago
I have a couple of very old hand planes that are pitted. I filled the pits with bondo then flattened them and waxed them. they work fine. mine are heirlooms [grand fathers] but not collectables. :-]
-- hey honey! watch this!
HokieMojo
68 days ago
Thanks,
I’m trying to start a small plane collection (collection of planes to be used, not admired for appearance). I bought a #5 and #7 so far. Now I’m looking for 3 and 4. I think those should give me a good start to my bench planes.
Sometimes the pitting seems to be worse on the sides because the planes may have sat flat on a shelf, which maybe protected tthe sole from oxidation a bit more (just guessing).
From an asthetic perspective, I’d like them to not look like they are held together with duct tape and chewing gum, but for the most part, if they function, I’ll be very happy.
Thanks again and it anyone else has more thoughts, I’d love to hear those as well.
View marcb's profile
marcb
199 posts in 210 days
68 days ago
#3 and #4 planes are plentiful, so don’t sacrifice quality.
View brianinpa's profile
brianinpa
941 posts in 260 days
67 days ago
If you are buying these planes to use, minor sufrace pitting shouldn’t affect the operation. If you are buying the plane as a collect: don’t waste your money. If the pits really bother you, fill them with any method mentioned here or even add some weld to the holes and re-surface the plane wher it has been welded.
View cmaeda's profile
cmaeda
99 posts in 91 days
67 days ago
Yes, as a user of old planes, I can tell you that the pitting will get worse over time if you don’t fill them. I will mine with epoxy and sand flat, otherwise, the wood dust accumulates in the pits, which attracts moisture and makes the pitting worse.
I found this out thje hard way when I took about 8 months off of woodworking (my wife was pregnant). When I started woodworking again, I noticed small bits of rust had formed in those pits. I wax my planes (along with all other cast iron surfaces) on a regular basis too.
skeezics
67 days ago
fill sand smoothe and paint. [sides and tops] I use epoxy appliance paint from a spray can. they look fine and as I said before they are users. I use automotive body filler [bondo] soles are waxed. pitted irons get replaced.
skeez
67 days ago
Anyhow, you don’t need a flawless tool to do good work. I have
a lot of old planes and it has never occurred to me to fill them with
Bondo. I guess several of my planes have some minor pitting here
and there but I’ve never had sawdust get caught in pits.
If you live in a humid part of the world pitting might be more of an
issue.
cmaeda
99 posts in 91 days
66 days ago
I leave my planes on a shelf I made for them. Initially, I thought it was cool but as I wood work, everything exposed gets covered with sawdust. I’m pretty sure that’s how the saw dust get caught up in the pits. An enclosure has been on my todo list (for the last 5 years).
Bookmark And Share This Page
